1972 Boler 1300 - Fiberglass RV
Old 05-20-2015, 07:07 PM   #1
1972 Boler 1300
In the process of refurbing 1972 Boler( no name yet).
Am replacing the axle and am trying to find the proper position for the centre of the hubs. Ideally from the rear of the frame. I am measuring 54". Does any one have any specs. Much appreciated.
Wayne
WISE LABS is offline   Reply With Quote
Old 05-20-2015, 07:11 PM   #2
Ian G.'s Avatar
Are you replacing with another Dexter torsion axle?
Old 05-21-2015, 11:03 AM   #3
It's not a Dexter, it is a Flexiride system c/w brakes custom assembled by Pacific Spring & Axle. The problem is that it had 4" arm instead of 6" so it is not just a put it back where it was. It will be welded to the frame so I am trying to verify that I have the correct position or is it critical as long as it fits the wheel wells and is square to the frame.
Old 05-22-2015, 01:07 PM   #4
My guess is that, yes, if the new axle places the wheels properly in the wheel wells including the headroom above the tire, and it's square to the frame, then it will work. The shorter arms may affect the way the rubber flex works, and you may get less shock absorption. But there's nothing else that's going to be affected by the slightly different spec.
72 Boler Restoration
BigEast is offline   Reply With Quote
boler
1972 Boler 1300 ReilleyS Referrals: Molded Fiberglass Trailers 4 03-18-2010 05:21 PM
1972 Boler 1300 before and after pics of interior Shane M Modifications, Alterations and Updates 2 07-08-2008 10:14 AM
1972 Boler 1300 Before and after shots of exterior Shane M Modifications, Alterations and Updates 4 07-06-2008 08:01 AM
SOLD - 1972 Trillium Trailer 1300 (13') for sale - $4500 Booker B. Classified Archives 3 05-16-2008 01:14 PM
