Scamp 13 dump system - Fiberglass RV
Old 09-19-2017, 08:13 PM   #1
Trailer: Scamp 13' 2017
Missouri
I purchased a Scamp 13 in May of 2017 from Scamp. A new unit and I had a problem on my way home with it. The black water drain is way back under the trailer and I have a problem getting down on the ground and getting back up. I had my son to help me and we added extensions onto the drain system so the drain hoses are out from under the trailer and able to connect the drain hoses without getting down on the ground. These are standard fittings that I purchased at Camping World. Hope this will help others that have a Scamp trailer with the same problem.
Leon H in MO is offline   Reply With Quote
Old 09-20-2017, 10:30 AM   #2
Good idea, but it looks like those parts are low to the ground. Will they be damaged if you go over anything sticking up?
Old 09-20-2017, 11:44 AM   #3
Missouri
Worked without problems
The wife and I took a 3300 mile trip and lots of rough roads across the North and west and had no problems with the drain pipes dragging. Did not get down on my knees one time to drain the systems. I was able to drain and rinse both systems in around 30 minutes each time. This was a 16 day trip and I drained the systems each time I left a camp site.
Old 09-20-2017, 02:18 PM   #4
Missouri
Wayne,
I forgot to state the I used Rhino 45 clear fittings and they swivel so it can swivel up under the edge of the trailer. See the attached pictures
dump hose connector... Herb P Care and Feeding of Molded Fiberglass Trailers 3 07-05-2007 01:56 PM
My dump valves work! Gina D. Plumbing | Systems and Fixtures 20 02-24-2007 04:09 PM
Relocated dump valve Mike Taylor Modifications, Alterations and Updates 3 11-14-2005 03:26 AM
How to dump into (and out of) blue tote tank? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 14 04-30-2003 03:05 PM
Public Dump Sites Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 04-03-2003 05:04 PM
