There is Good and Bad in using
Scamp hinges (which I have now on my Boler)
Bad
1) None of the holes align with the original mounting holes, both the spacing and the locations are different
2) Each leaf of the hinge are not
parallel, in that they do not lay flat from the
Boler body to the door. Shims or spacers need to be installed under the door side of the hinge for the door to lay flush and close tight
Good
1) the hinge offset is better when opening and allows the door to fully open back before it hits the belly band
2) the hinges are stronger with the additional bolt on the body side hold the hinge better with less slipping
Because you have to drill new holes I made steel plates for the inside that are drilled and align with the mounting holes. Large fender washers could also be used but would not distribute the load quite as well.
