Oliver insulation - Page 2 - Fiberglass RV
Old 08-06-2013, 02:54 PM   #21
Brian B-P's Avatar
Originally Posted by chuckd View Post
The 22 foot is not only longer but wider and taller, not sure of the exact dimensions.
Originally Posted by cpaharley2008 View Post
Their dimensions are on their website, here Specs & Floor Plan - Oliver Travel Trailers
looks like 6"2" wide interior and 6' 6" wide exterior and 6'1 interior height.
A 6' 6" wide exterior will not likely be wider than the earlier model... it is narrower than an original Boler! Did anyone keep a record of the original 17-foot Oliver specs?
A longer trailer is typically taller if only because the ends must be higher for ground clearance. A longer trailer's frame is also typically deeper, for strength, pushing the height up further.
Now, if only I had more faith in dimensional information published by manufacturers...
(A different manufacturer continues to publish that their crosswise bed is as long as the outside width of the body, indicating that there's no curve in the body and that the walls have zero thickness... even after the impossibility was pointed out to them and acknowledged.)
Old 08-06-2013, 06:44 PM   #22
Brian B-P's Avatar
Now depending on the weight of the thinsulite, it might have an R value around 4/inch.
That seems reasonable for a soft foam: higher than fiberglass batting, but a bit lower than polystyrene foam.
That's R-4 per inch of thickness: does anyone know how thick it is? For instance, a quarter inch thickness would provide R-1 of insulation. At that sort of thickness it would be similar to the foam-backed liner used by Escape. We're not talking house levels of insulation here...
Old 08-06-2013, 06:57 PM   #23
Trailer: In the market
Minnesota
Insulation thickness
Bob said that the gap is about 1 to 1.5 inches. Also headroom about 76 inches, and I think 84 inch width. (maybe 86)
Chuckd
Stillwater Mn
chuckd is offline   Reply With Quote
Old 08-06-2013, 07:07 PM   #24
Brian B-P's Avatar
It's hard to understand wasting that much interior space... but okay. Still, it seems unlikely that they are filling that with Thinsulate, but I suppose they could be... or they could be putting a thin layer of Thinsulate on the shell, and leaving an inch of air gap.
That width makes more sense, and is similar to some of the old "widebody" designs such as my Boler B1700.
Old 08-06-2013, 08:25 PM   #25
GPJ
Trailer: Looking
The original Olivers had (according to their brochures) an outside width of 6'6" for the 17' models and 6'11" for the 22 foot models (both sport and elite). So either their current website is wrong or they have reduced the width of the 22' model. I'd guess that their website is wrong, but they also seem to have changed the outside height to 8'7"(current site) whereas before the 22' model was 8'6" (interior height 6'6") and the 17' model was 8'4" in outside height.
GPJ is offline   Reply With Quote
oliver
Insulation Chris Jones Modifications, Alterations and Updates 4 07-21-2013 05:35 PM
insulation Hazel in Sk Problem Solving | Owners Helping Owners 9 07-15-2012 08:43 AM
Insulation Brian Tin Problem Solving | Owners Helping Owners 12 11-02-2010 08:02 PM
08 Oliver Tom Trostel Referrals: Molded Fiberglass Trailers 1 02-25-2010 07:13 AM
