We are selling our beloved Casita! We have taken it to several Burningman events and it has been great! We are now looking to move up!
1986
Casita
16 feet
Sleeps 2 in the rear, and one on the side cushion. Best for a couple, maybe with a kid. We had 3 adults on one trip and it was tight. We did it, but that was the only and last time.
Headroom is like 5'9". I'm 6'0" and have to tilt my head a little while standing inside.
The
Casita is a very
light fiberglass trailer that can be towed with a small vehicle. These are great little trailers and there is a huge following for them.
The trailer has been modified a bit from it's original configuration to make it more suited for our needs. We basically removed the table from the rear that converts to a bed and made it a permanent bed. We never sat at the table, and the cushions were not very comfortable. The bed was made from very high quality foam and the bed frame was made from aluminum that was cut / welded to make a solid and
light platform.
It could easily be converted back if you wanted a table. We always sat outside, under the
awning.
It has electric
brakes (that require a brake controller to be installed in your car), however we never felt we needed to use them. I have a brake controller, new in the box, that will go with the
Casita.
Some details:
It has an
air conditioning unit in the back window. It's not pretty but it works great and is the source of a lot of compliments.
The toilet and shower work great.
It has a 25 gallon fresh water tank (i think) - I know it has a water tank, but I'm not sure of the capacity
It has a 2-burner
propane stove that works great.
It has LED
lighting inside the perimeter of the inside. You can control the color and brightness.
There is a
microwave that works good. You have to be on a
generator or plugged into 110v shore power for it to work.
The original
fridge was replaced with a dorm room
fridge. The new
fridge has a bigger capacity but needs to be plugged into a
generator or shore power for it to work.
There is an
awning on the side that opens up (manually) and either attaches to the side or the ground.
There are LEDs around the outside of the Casita that you can change colors. It makes it really easy to find the trailer in the campground, plus it is really cool.
There is a
solar panel on the top, with a charge controller that charges the
battery.
The
tail lights and side
lights were replaced with brighter
LED lights.
12 volt plugs inside so you can charge phones, etc.
It has a 7-pin trailer plug.
2" trailer hitch that was recently replaced.
It has a spare tire. Condition is suspect, but it's there
The trailer is registered with a permanent trailer
registration - no more DMV fees!
Lots of miscellaneous stuff.
Some things that need attention:
The hot water heater needs a new cover and a little work. Someone backed into the trailer while it was parked and there is some minor
fiberglass work that could be done to make it perfect. I never got around to fixing it. I was going to put in a new hot water heater with electronic ignition. The one in it now uses a pilot
light. Honestly, we never used the thing.
The vent on the top is old and should be replaced with a fantastic fan or something like that.
It could use new
tires soon.
There was a stereo in it, but that broke. There are speakers installed.
It needs a little TLC or more customization to make it yours!
