04-20-2015, 07:31 AM
#61
Trailer: 2017 Scamp 16 Deluxe
Missouri
ParkLiner & Ford Escape
Ok. I looked up the Curt instructions ....
"NOTE: Stoplight switch connection on Ford vehicles including, Mercury Mountaineer. Do not connect to the red wire with a green stripe. Connect to the light green wire only."
I guess there may be a couple of wires that might seem right, but the blue P2 wire should only be attached to the light green one. ??
Because the Prodigy RF avoids the whole issue of which Ford wire to tap into, I never actually looked at those wires. I just remembered the note because we had the Curt TriFlex in our CRV.
Ray
Sent from my SCH-I545 using Fiberglass RV mobile app
04-20-2015, 07:40 AM
#62
Trailer: Trillium 2010
Originally Posted by honda03842
Raz,
This should not be a Ford issue. The controller is really an independent device. It should see the presence of the trailer brakes, mine does even with the engine off. Yes an RV shop should be able to fix this problem.
I fully agree. That's why I suggested the measurements at the controller plug and the 7 pin. These measurements will identify any fault. In wiring a brake controller the only tricky connection is finding a brake on signal. Twelve volts on the red brake controller wire when the pedal is pressed confirms he got the correct line. Frank says he dd these measurements and took notes?? He should check his notes. Raz
04-20-2015, 07:44 AM
#63
Trailer: 2012 ParkLiner #006
I'm pretty sure I didn't attach it to a wire with any red on it Ray, but it sure seems to me it was a wire with a stripe.
This is very frustrating, as I can't look until I get home after work!
Thanks for checking that out for me, much appreciated.
Frank
Ray
2012 ParkLiner #006
04-20-2015, 07:46 AM
#64
Missouri
If he connected to the red wire with the green stripe, the Curt TriFlex install instructions would seem to suggest that could be the problem.
Ray
04-20-2015, 07:49 AM
#65
Missouri
No problem, Frank!
I know how frustrating some of this stuff can be.
Best of luck to you! 😊
I sure hope you will let us all know how this turns out. I'm now really curious. 😉
Ray
04-20-2015, 07:58 AM
#66
Name: Norm and Ginny
Trailer: Scamp 16
Test
There are four Prodigy wires.
Black is +12 vdc
White is ground
Blue goes to the trailer brakes
Red goes to the tow vehicle brakes depressed switch.
The controller should see the trailers brakes with or without the brake (red wire) connected.
I connected a spare brake coil across the two pins of my tow vehicle, on my connector the two pins at the bottom of the connector. The 'c' came right up on the Prodigy display without doing anything.
Just about any resistor will work, 10-25 ohms. The wattage is not critical. It will just burn out after a while if it's too low.
If the c comes on it means the two connectors, ie. trailer and tow vehicle are not wired the same.
If the c does not come on try the test at the Prodigy's connector.
If you have some one watch the prodigy's display you can skip the resistor and just quickly short the two pins, You may not get the 'c' but you will get an overload signal showing the wires are there and work.
Be sure you know which two wires are the brake and ground on your trailer connector.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
04-20-2015, 08:14 AM
#67
Missouri
Thanks for correction/clarification, Norm!
I learned something and, for me, that's always good!
So maybe disconnect the red and leave the blue connected and then look for the trailer bakes indication?
Then hook up the red wire to the proper Ford stoplight switch wire and see what happens?
Since Frank bought his parts from etrailer.com, it seems like they should be able to help identify the correct wires?
Just a thought.......
Ray
04-20-2015, 09:13 AM
#68
Trailer: Scamp 16
Frank,
When you connect the Escape to the trailer do all the other functions work properly...brake lights, turn signals,...
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
04-20-2015, 11:26 AM
#69
Originally Posted by jennykatz
Is this normal to have problems with brake wiring or is this a ford escape problem ? Would'nt a RV place handle this easily ?
My experience with a similar frustrating issue with a Subaru would suggest that yes a hitch shop may be able to pin point the actually issue quickly. In my case it was a tiny electrical modular box built into the 7 pin towing harness that was attached to the factory installed 4 pin system that was malfunctioning.
Took the shop less than 10 min to find & fix the problem. Funny enough I had told the Subaru dealer about the problem and asked they check the cars computer for an error code - they didnt find one as the car was doing what it was suppose to do - it was the box it was talking to that wasn't.
04-21-2015, 08:42 AM
#70
Frank, When you connect the Escape to the trailer do all the other functions work properly...brake lights, turn signals,...
Yes Norm, everything has always worked fine for everything but brakes.
Last night was not a good night to play with the Escape. I will try and get at it soon with all the ideas that have been brought up here. As usual, I have been taking notes...
Thanks all!
Frank
2012 ParkLiner #006
04-23-2015, 08:22 AM
#71
Last night my thing was to make sure I had the cold wire of the brake pedal hooked to my red wire coming from the controller. I ran a ground from the engine compartment, and stuck the pointy end of my 12V tester into the connector from the brake pedal wire to the controller (red) wire. Nothing until I depressed the brake pedal, then the light came on. So, I know (again) that I have the correct wire from the brake wire harness.
Next?
Frank
2012 ParkLiner #006
04-23-2015, 08:30 AM
#72
Norm, Radio Shack here has 10 ohm resistors, but none with more than a 1/2 watt rating. Would that work, or should I see if they have a 25 ohm with a higher watt rating? I have to hurry, as they're closing at the end of the month here.
Thanks. I need to figure something out!
Frank
Black is +12 vdc
White is ground
2012 ParkLiner #006
04-23-2015, 09:20 AM
#73
Trailer: Scamp 13
I would check the actual voltage on the brake line. Your voltage may be too low. Allot of cars have reduced wire sizes and added relays to carry the real power instead of large heavy wires running all through the harness these days.
Check the voltage on the same line you used in the truck and compare it to the voltage in your Escape. You may just be tapped into a low voltage signal wire and not a true power wire. Are your brake lights LED or incandescent on that Escape?
I was looking at your generic instructions on your P3 and it has a diagnostic screen telling voltage when hooked up. If you know you have voltage on the line and the unit in your truck works properly so you know the box is good then the issues must be in the brake signal wire in your escape. I assume you have a separate harness between the truck and your escape and you just plug in each harness to the prodigy when you swap. I would suspect a bad connector or broken wire in the plug at the prodigy on the escape side. Trace the wire from the brake switch unplugged from the prodigy and check for voltage with the brake pressed at the unplugged connector at the prodigy end. If you have voltage I suspect the pin is spread too loose or maybe pushed back inside the connector. There must be a reason that it isn't making connection.
If there is continuity between the brake and the prodigy when plugged in you should see voltage on your diagnostic screen on your prodigy.
04-23-2015, 10:29 AM
#74
Let's go over this bit by bit.
I can try and measure voltage on the brake wire. I need to also study my Prodigy instructions, see if I can glean anything I may have missed.
I did not "use" any lines in the truck. There was a plug under the dash to hook the controller to, and I got the right harness from NAPA to do that. Out back, I just separated the wiring harness, inserted a "T" connector and had my 7 pin plug. Works seamlessly with the F150. I am continually at a loss why Ford did not make this 7 pin thing easier with a vehicle they promote with 3500# tow capacity. Gee.
I have two Prodigy harnesses. One that just plugs in under the dash of the F150 and stays there, and one that had wires to be attached for the Escape. The one for the Escape I have already swapped out once (along with the 7 pin plug out back) just to make sure it wasn't a plug. Nothing changes.
I'll try and do some voltage checking tonight.
In the meantime, I'm in the process of rebuilding two boat trailers and my hot rod. Money from selling the boat trailers goes towards the hot rod rebuild. I have my hands full, but I want to get this Escape 7 pin wiring thing dealt with soon. I have to be close!
Frank
2012 ParkLiner #006
04-23-2015, 06:15 PM
#75
You're all gonna laugh at this one. Norm figured it out. The Escape is wired correctly, but the brake connection and ground connection on the 7 pins are reversed. I.e., I need to either swap the F150 and Parkliner plugs to match the Escape, or swap the two bottom connections on the Escape and be done with it.
A lot of testing of the Escape went on before we got to this place, but it was Norm that figured it out. My sincere appreciation to all who offered suggestions!
Frank
2012 ParkLiner #006
04-23-2015, 07:51 PM
#76
Trailer: Scamp 16
The rest of the story
The Prodigy controllers check for the presence of the brake coils, basically the integrity of the wiring from the Prodigy controller all the way thru the brake coils by sending a small current continuously through the brake coils. The current is so small that it does not activate the brake's coil.
By reversing the brake and chassis ground wire, both ends of the brake coil are connected to chassis ground and no current can flow therefore the controller assumes correctly no effective connection.
Frank found that when he connected a resistor between the brake pin and chassis ground pin at the tow vehicle connector, the Prodigy controller worked. This indicated it had to be a wiring problem and probably in the tow vehicle connector since the trailer worked with his Ford Pickup.
A nice problem with a happy ending for Frank. And why is Radio SHack going out of business, we all need resistors.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
04-23-2015, 08:15 PM
#77
Trailer: Escape 19 and Escape 15B
Way to go Norm.
Glad it worked out for you Frank. I think I would have given up long ago and switched to a wireless controller.
Dave W - 2013 Escape 19', 2013 Escape 15B and 2011 Toyota FJ Cruiser
"You've got to be very careful if you don't know where you are going, because you might not get there." - Yogi Berra
04-23-2015, 09:35 PM
#78
Trailer: 93 Burro 17 ft
Who installed that plug on the Escape? The dealer?
04-23-2015, 09:38 PM
#79
Frank, I'm not an electrician by any means, but I'm still trying to sort out something about your wiring problem (now solved!). Did you do all of your initial diagnostics with the camper hitched to the tow vehicle? If so, then that means the camper and tow vehicle shared at least somewhat of a common grounding through their hitch contact. And I'm guessing that's the case or your clearance lights wouldn't even have worked without a functional ground wire connection. Is that right, and does that make sense? If so, and if the frame of the camper was already somewhat grounded to the tow vehicle through their common hitch contact, then when you stepped on the brake, you were sending electricity from the tow vehicle into the ground wire of the camper, which in turn is likely attached directly to the frame of the camper as part of the grounding of the camper's wiring system. If true, then this all means that you would essentially create a "dead short" every time you stepped on the brakes. And if that is right, then shouldn't that have blown a fuse somewhere each time you stepped on the brakes? Again, I really don't know if my thought process above even makes sense. I'm just curious to know what I'm missing in all this. You never know when I might need to know this stuff. Anyway, I'm glad you finally have it figured out and know what needs to be done to fix it... Dale
04-24-2015, 04:02 AM
#80
Frank, you made the same mistake over and over every time you checked the wiring. Been there, donevthat. Welcome to the club!
Mine pulses. If I sit quietly in my trailer I can hear it. Made me smile when I figured that's what it was.
You lost me here. Shorting the coil I would expect more current not less. I think there is more going on. The folks who designed these controllers did some clever stuff. My guess is they pulse to preserve the battery. During the pulse they sense the resulting current. If it falls outside of a window, too much or too little the controller indicates the fault, i..e. NC. This would give a more accurate representation of the condition of the brake circuit.
Another possibility is, as Dale suggests, crossing grounds would disrupt the light circuits and perhaps disabling the brake pedal signal when connected. In any case a good puzzle for sure. Raz
