The New Subaru Ascent as a Tow Vehicle for a 17 foot Casita - Page 4 - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Towing, Hitching, Axles and Running Gear
Old 07-22-2018, 08:56 PM   #61
trainman's Avatar
Trailer: 2019 Oliver Elite II
Originally Posted by Gilda View Post
Brilliant! You "Googled" it! Why did I not think of that?
We have no truck weigh stations near us in the San Francisco Bay Area. I'll have to wait until our next trip. I have to say, I do love truck stops for their mini-marts and for people-watching. I do feel a bit intimidated though with my tiny Scamp being towed by a tiny vehicle. I find the people who work at truck stops to, generally, be very friendly and accommodating, though. I'll ask about a weigh-in next time I'm in a truck stop (as long as they don't think I want a personal weigh-in ).
Ask a truck driver in the parking lot, I find that people who work in places like that really don't know where anything is, remember most young people have tunnel vision and are lucky to find there way to work.
trainman
trainman is offline   Reply With Quote
Old 07-23-2018, 12:01 AM   #62
Borrego Dave's Avatar
Originally Posted by trainman View Post
Ask a truck driver in the parking lot. trainman
Trainman has the correct answer Gilda, truckers can give you locations for every state
Old 07-23-2018, 08:45 AM   #63
Trailer: Casita 2019
FL
Hi All. Thank you for the advice. I will be taking it and looking elsewhere for a TV. I will sending in the deposit for my 17' foot Casita shortly and it will take 4 months before I have to go pick it up, so I need to get my tow vehicle...very exciting. I did drive the new Subaru and of course loved it, but I will take your advice which reinforced my concerns. I am most grateful to have this resource and the input of people who know more than I!
Debbie in Florida is offline   Reply With Quote
Old 07-23-2018, 09:05 AM   #64
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Good luck with your new trailer Debbie. Please check in with a picture or two when you get it.
Walt
Old 07-23-2018, 10:03 AM   #65
frank_a's Avatar
Trailer: 2012 ParkLiner #006
We towed our Parkliner with a 2012 Ford Escape 2 liter ecoboost (turbo charged) with the factory 3500# tow package many a mile. It wasn't ideal, but did the job it needed to do!
Frank
2012 ParkLiner #006
Old 07-23-2018, 10:29 AM   #66
NW Wisconsin
One thing to remember is that the average tongue weight of a 17 ft Casita when loaded for travel is 427 lbs ( Source Trailer Weights In The Real World)
We own a Casita 17 ft SD and our tongue weight when loaded for travel varies
between 420 & 430 pounds
Old 07-27-2018, 08:47 AM   #67
Trailer: scamp
New Mexico
Sounds like the original poster has moved away from the Suby Ascent which I personally think is a good decision. FWIW, I called Subaru dealer and asked about the torque figures on the Ascent. I asked whether the turbo was always engaged or only under load. The salesman said that the torque mentioned (277 ft lbs) occurs when the transmission shifts, i.e. when the tranny shifts down, the turbo kicks in to give a power boost. That doesn't make a lot of sense to me and I am not sure the salesman really understood. But, if that is how it works, the car would have great pull power for short bursts but then when the turbo licked out, it would return to more typical gasser torques which would be much less. On a long grade, you could envision a car constantly cycling between gears, turbo cutting in and out, to keep the vehicle speed up. Does not sound ideal to me.
semievolved is offline   Reply With Quote
Old 07-27-2018, 08:48 AM   #68
Trailer: scamp
New Mexico
oops, meant "kicked out" not "licked out"
Old 07-28-2018, 01:28 PM   #69
John in Santa Cruz's Avatar
Mid Left Coast
neither of those descriptions sound like any turbo system I've seen or worked on. the amount of boost at the intake manifold is a function of the exhaust output, as modulated/limited by a waste gate to prevent overboosting, and by the throttle to modulate how much of that boosted air the engine actually gets.
Old 07-28-2018, 01:58 PM   #70
Roger C H's Avatar
Wink CVT
A CVT or Continuously Variable Transmission, has two variable pulleys with a transmission chain between. The chain moves up and down the variable pulley while moving down and up the other variable, thus adjusting the ratio between the two instead of using incremental gears.
It is a little disconcerting at first because there is no gear shifting. I notice on ours that when accelerating, the engine rpm stayed the same, yet the car speed increased.
https://www.planetsubaru.com/lineart...ansmission.htm
Disadvantages I have learned is that if the same ratio is maintained for long periods of time, that spot on the transmission pullies can wear and cause surging entering or leaving. Also, my dealer said that we should get the transmission oil changed more often if towing and the oil is expensive. We have a 2014 Outback.
casita
OK to tow with Subaru - mixed messages Signterp Towing, Hitching, Axles and Running Gear 36 07-22-2017 10:25 AM
Subaru Outback enough to tow Scamp 13' ft.? Lonely Road Problem Solving | Owners Helping Owners 50 06-03-2016 08:33 AM
Long Road Trip with Subaru Forester and 13 Foot Burro John Colangelo Towing, Hitching, Axles and Running Gear 8 06-29-2015 07:16 AM
Subaru tribeca as tow vehicle Meghan Towing, Hitching, Axles and Running Gear 3 09-17-2014 10:57 AM
Wanna tow Scamp 16' with Subaru Forester DavArl Towing, Hitching, Axles and Running Gear 158 03-13-2012 09:07 PM
