Casita 17 Cabinet Door Hinges - Fiberglass RV
Old 08-22-2018, 06:17 PM   #1
Trailer: In the Market
Connecticut
Hinges on my Casita Spirit Deluxe 17’ are showing surface rust. I’ve looked into buying replacements and have been told that these are generally available commercially – standard cabinet hinges. I’ve tried to buy look alike hinges, several different ones. While I can get the screw holes aligned pretty well what I’ve discovered is that the design of the replacement hinges create a bit more offset which prevents the doors from closing properly. Any ideas as to where I can find the correct hinges. Casita says buy at your local big box, not getting it done.
Ed Wiz Connecticut is offline   Reply With Quote
Old 08-22-2018, 08:18 PM   #2
Standard "out of the bin" hinges at any big box store. You want ones with a 1/2" offset. I've replaced several, and they're pretty much a standard hole pattern.
Old 08-22-2018, 10:13 PM   #3
I've recently replaced the hinges for the same reason. I found them at the local Lowes store for about $2.00 each
CalCop is offline   Reply With Quote
casita
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 12:39 PM
Replacing 1974 boler hinges with new scamp hinges ArneB Modifications, Alterations and Updates 2 08-10-2015 12:39 PM
