Interior A/C unit recommendations - Fiberglass RV
Old 08-09-2018, 11:35 AM   #1
Trailer: Amerigo F-16 1978?
New Hampshire
Dometic COOL CAT
Under the cabinet Heat Pump 10,500 BTU - For Campers
https://www.dometic.com/en-us/us/pro...ol-cat-_-20787
I have a flat roof Amerigo F-16 with minimal support. I really do not want a 100lb+ A/C unit bouncing around up there!
Interior is 14' x 6' x 8' and will be well insulated.
Please tell me who is a good Manufacturer and any ratings would be great.
I see Dometic has other models for trucks and boats that may be applicable.
Thank you
Jonathan
JonnyX151 is offline   Reply With Quote
Old 08-09-2018, 12:52 PM   #2
sokhapkin's Avatar
SW Florida
8000 BTU window A/C unit should work fine for your application and cost only a fraction of the price.
Sergey
sokhapkin is offline   Reply With Quote
Old 08-10-2018, 10:32 AM   #3
IF it's "well insulated", a GE 6050 would do it. But my 9000 Coleman, out in the hot 93+ degree summer sun has to run almost continuously to keep my 13' Scamp cool as I want it :-) The Scamps are not that well insulated regardless what they state.
But most certainly the 8K just mentioned would do it. It's just a little larger and heavier.
Old 08-10-2018, 06:46 PM   #4
The claimed R15 insulation in the new Scamp is bolderdash.
The Reflextex cannot be pressed against anything as it's claimed performance depends on the low emissivity of the aluminized surfaces.
If it is against anything the the aluminum conducts quite well.
Old 08-11-2018, 11:24 AM   #5
Trailer: 1989 Casita 16 footer
Interior mounted AC
My 16 foot Casita had the original Ac in it,but wouldn't cool it good enough.
I bought a Frigidare 10,000 BTU,same physical size.Draws only 8 amps.Even has an economy mode and remote control.
It will cool down our Casita on a hot day pretty quick.Always have to keep it on low.
I highly recommend a Frigidare
Eddie B. is offline   Reply With Quote
Old 08-15-2018, 07:00 PM   #6
Trailer: Capita SD 17
New Mexico
What model Frig?
Trapperbill is offline   Reply With Quote
Old 08-15-2018, 09:06 PM   #7
Trailer: Currently Shopping
Minnesota
I own an A-Frame camper. Most A-frame trailers use a Dometic CoolCat AC/Heat pump. They work well. I use it for both cooling in the summer and heating in the fall. My understanding is that they are specifically built for RV use, so they can stand up to the continual pounding of the traveling trailer. However they are not cheap.
Alben is offline   Reply With Quote
Old 08-22-2018, 09:20 PM   #8
Everywhere
Yep. Actual Scamp insulation R-value is about 1.1 or so.
eco
Recommendations for new interior lights? KellyNC Electrical | Charging, Systems, Solar and Generators 5 03-22-2016 08:54 PM
recommendations on new interior wall covering? LukeP Problem Solving | Owners Helping Owners 6 05-15-2011 06:36 PM
What did santa leave for your unit? Chester Taje General Chat 22 12-28-2005 05:54 PM
A/C Unit in Scamp 13' Jim Paskett Modifications, Alterations and Updates 1 12-01-2005 10:56 PM
