1978 Ventura - Seeking advice - Fiberglass RV
Old 10-16-2018, 03:49 PM   #1
Trailer: Ventura
Hello! I'm new to the fiberglass trailer world and new to this forum.. Pretty excited about both!
I have a 1978 Ventura that was partially gutted and is being completely gutted as the previous owner did more harm than good (screws from inside puncturing the fiberglass roof, etc).
More parts are missing than present so this is a 'from scratch' project.
Anyways.. I've enjoyed the wealth of information on here and am hoping for more information and advice as we work through the restoration.
I'm looking for advice on removing the shell and storing it temporarily.
What do you wish you're trailer had that it doesn't?
What did you keep or include in your trailer build that you don't use or wish was gone?
I'll post more questions as we progress.. need to pace myself haha.
I've added some pics below.. wood floor wasn't too bad (I don't think the water had been sitting very long) but all the flooring has been removed.
Any and all advice is appreciated! Thanks!
ID:	125513Click image for larger version
thedubler is offline   Reply With Quote
Old 10-18-2018, 05:36 PM   #2
MurrayC's Avatar
Trailer: Ventura
British Columbia (BC)
Ventura chat
Warren
Please send me your email address to cherkas@shaw.ca
I won't be here tonight. Sorry
MurrayC is offline   Reply With Quote
Old 10-18-2018, 06:07 PM   #3
Bigger bed and bigger dinette are my two items on the wish list. The location of the door limits dinette size unless you have the dinette bench larger on the street side and narrower on the curb side.
Old 10-18-2018, 10:19 PM   #4
Trailer: Trails West
is your house battery going to be inside or outside? If inside then adding a built in port for plugging in a portable solar panel is a good idea. The best time to install any thru the wall ports is before you insulate. That way you can add blocking on the inside where they go so that the mounting screws have some wood in the interior to thread into. So be sure you think carefully about what modern devices you or future potential owners will consider to be nice to have features.
It is nice to have a 12v outlet on the exterior, near the exit door; use a marine version with a water tight cover over the socket. You can use that with a USB adapter, for 12v air compressor, a string of 12v exterior lights, 12v portable table fan, a radio, tablet, phone charger, bug zapper, etc. Remember that area usually functions as an outdoor living room. The plug-in socket allows you to keep the screens closed without having a cord threaded out a window or the door.
You might want to add a port somewhere on the side or roof for installing a cable to a radio, cell phone or TV antenna.
If you are going to have solar panels on the roof the time to get that external port installed is before you insulate. It is also the time to install blocking on the interior side of the roof so you can screw the mounting brackets for solar into those blocks for extra security.
In my trailer I bonded some plywood plates to the underside of the roof to mount my interior overhead and wall lights to.
I have a trailer that needs a support pole that starts at the countertop and helps support the ceiling so I also put in blocking against the ceiling for that function.
Just think it all through carefully before you put in any insulation, now is the easy time to get your blocking in. Also be sure to take photos of the blocking, print the photos out and add in some dimensions showing the distance to the blocking from a known, fixed point such as the edge of a window frame, door, the floor, etc. You can even add in some blocking for some future application you might want to add a few years from now. For instance I put in a plywood plate to support some fuel canisters I might want to add to the front or rear of the trailer should I decide to be off grid and need extra gas for a generator. I don't know for sure if I will need them but if I do I am ready to bolt them right in knowing that they will be well supported.
Old 10-19-2018, 08:11 PM   #5
Trailer: Ventura
Wow, brilliant. Had thought of some of these things but some fresh, new ideas here I'll hopefully put to use. Thanks!
Old 10-20-2018, 10:28 AM   #6
I much prefer a battery outside than in. First, indoor storage is at a premium. Secondly, traditional batteries need to be vented to the outdoors = more holes through the wall of the trailer, and a sealed box. Third, less important, but its a lot easier to maintain and check a battery when it is outside, than buried in a cabinet somewhere.
If I put a battery on my old Trillium, it will go outside for sure.
ventura
Seeking advice re: 19 ft. Scamp 5th Wheel Bonnie Witt Problem Solving | Owners Helping Owners 34 03-25-2016 08:51 AM
Still seeking options advice Bill in Pittsburgh General Chat 21 09-25-2013 09:11 AM
Seeking AC advice Steve_N_Janna Problem Solving | Owners Helping Owners 2 10-06-2011 07:41 PM
Seeking your advice on a Scamp 13' purchase Bill caulway Problem Solving | Owners Helping Owners 7 08-06-2010 09:44 PM
