Bigfoot Solar System - Page 2 - Fiberglass RV
Old 07-23-2018, 01:46 PM   #21
richardr's Avatar
Trailer: Escape 21
Originally Posted by Steve and Rosemary View Post
Hi Rick, I'm glad to hear it went well. It sounds like you connected your panels in Parallel, right? So did you put a switch in at all? I guess you could remove a fuse which would act like a switch, right?
Any thoughts you'd be willing to share on portable vs. roof-mount would be helpful. I'm trying to decide between flexible (lightweight) and rigid (durable) panels and am weighing the benefits of both roof-mount and portable setups. Do you find hauling the 100 watt panels around is a pain or is it doable?
Thanks for letting us know what you ended up doing. Happy camping!
Yes, the panels are connected in parallel.
I find the portable panels to take about 15 minutes to deploy. They are both a pain and doable. I have a cable to lock them with, but it is not all that secure, so I don't want to keep them out when we are not around. I keep the panels on a rack that rests on the top of the widow frames in our truck bed cab. We went with portable because wife wants to camp in the shade whenever available.
Sometimes I wish I had a panel mounted on top of the Escape roof. It would be very handy while driving or when we overnight at Walmart or a truck stop.
I think if we were more willing to camp in the sun, I would have gone with the roof top mounted panel.
Rick and Vicky Reed
richardr is offline   Reply With Quote
Old 07-23-2018, 02:03 PM   #22
ZachO's Avatar
Trailer: Sasquatch
Montana
This is also my experience. I bought portable panels at first to avoid drilling and mounting to the roof. Now I love them because I camp in the shade whenever possible.
But I also stealth camp around town fairly often, or in areas I don't really trust leaving the panels out. But I need to charge the battery...For this reason I'm convinced that I want roof-mounted panels in addition to my portable panel. Both would be really, really nice. If I had to only have one type...for my personal type of trailer use, I guess the portable are more adaptable to different situations. I've left my camper in the work parking lot for a few days when I was out in the field, and used a ladder to haul the panels to the roof and left them there while I was gone, laying flat. A pain, but workable. Much less chance of theft, and still a good charged battery when I got back.
But both is definitely the best option.
The portable panels can be a pain. I bought a package which included folding panels (90w), a few different battery-connection choices and an aluminum case. The case really helps. The photo shows how I transport it. Silver case on the left. Between getting the case out, pulling out the panel and standing it up, then putting the case back in my truck 15 minutes would be the absolute max. Probably not more than 5 if I'm motivated. I have a ratchet strap holding the case in place.
Luckily there's not much theft where I live. It only takes once...but so far I've had good luck leaving the panel sitting out while I'm gone during the day. No lock.
It's heavy and it takes up space and a little time, but it's the only way I have to charge my battery so it's just part of setting up camp.
When I save the money, though, roof-mount panels are definitely happening.
Old 07-23-2018, 04:52 PM   #23
Trailer: 89 Scamp 16 ft
Camping in the shade is pretty important to us too. Plus, I am a little unsure about mounting anything to the roof right away; I'd like to confirm my calculated usage and needs before doing anything permanent. For both of these reasons, I've been leaning towards starting with a portable set-up that could later be turned into a roof-mounted one.
Thanks to you both for your feedback and updates.
Rosemary (not Steve)
LUCINDA 1989 Bigfoot 5th Wheel | Steve, Rosemary, Maude Pod & Tripawd Hope
'Glass trips: Moab 03/10 * The Swell 5/26/11 * Antelope Island 12/21/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 7/15 * East Fork of Black's 6/16 * St Mary-Ennis-Lava 6/18
Steve and Rosemary is offline   Reply With Quote
Old 07-25-2018, 07:57 PM   #24
Trailer: In the market trying to decide.
AL
Originally Posted by Tim D. View Post
Thanks, George. As I mentioned, much of the credit goes to HandyBob, who seems to be able to cobble solutions from scraps. We benefited from our experience living for 9 months in the first Bigfoot 17, so when we met HandyBob for upfitting the second Bigfoot 17 we knew what we wanted.
I'll go more into the electronics in a subsequent post, but to answer your question our theoretical maximum current is 4 x 4.63, which puts us over 18 amps. I believe we had that today. We ran the fridge on 120v from 9am to 4pm and will be at 100% charge by sundown.
We use a Morningstar Tristar PWM controller. I may one day get the MPPT version of that controller, but for the moment I am satisfied.
Very nice set up but I would upgrade to the MPPT version when able they work better in my experience. I know things have drastically changed in Solar in the last few years so it would not hurt to check it out. If you are happy with what you have I understand. I would not be in a hurry to replace it but I would do the research for when you are ready to. System is awesome. Cant wait to see the batteries and rest. Thanks for posting. Jim
cptnjim is offline   Reply With Quote
Old 07-30-2018, 12:45 PM   #25
Trailer: Bigfoot 17'
B17 Solar Solutions?
Well Done! Working on my B17 now and contemplation the solar install. Interested in any input.
Garnet is offline   Reply With Quote
Old 01-31-2020, 07:42 AM   #26
I am going to put a solar system in my 21' 2008 Bigfoot. I am in contact with Bob as well or I should say my wife Daniela has opened the path to a future conversation. I would like to not put solar panels on the top of my trailer. Is it feasible to use a portable panel system that is deployed on site and keep a smaller semi permanent panel on the top of my truck cap for trickle charging while moving?
zorrou812 is offline   Reply With Quote
Old 01-31-2020, 08:54 AM   #27
OCJohn's Avatar
Trailer: Hymer
What are your objections to mounting panels on the roof? A semi permanent panel on your truck would need an awfully long cable. Would that be less hassle than a small panel on the trailer for the same purpose?
Different but related, I picked up some “charge while moving” capacity just from upgrading my trailer connector cable to one with 10 gauge charge wires from the vehicle alternator. If yours only has 14 gauge charge wires like mine did, that might be an easier, more practical upgrade than a panel on your TV running all the way back to your trailer.
Bob’s been helpful to me also. See what he thinks. He’s been very generous with his time (and much less intimidating than he comes across on his blog ). I think what you’re suggesting is doable, I just wonder if there’s a simpler way to overcome your objections to panels on the trailer. See what he thinks. He strikes me a a good out-of-the-box problem solver. Either way, best wishes for you with whatever system and solution you go with.
OCJohn is offline   Reply With Quote
Old 01-31-2020, 09:14 AM   #28
OCJohn's Avatar
Trailer: Hymer
Originally Posted by gordon2 View Post
Of course it is.. and IMHO it is generally the preferred method...
Did you miss this part – "smaller semi permanent panel on the top of my truck cap"
I don't know that I've ever seen that.
Old 01-31-2020, 09:54 AM   #29
No I missed that.. my bad. off topic reply was deleted.
But to answer the question asked, yes it is possible. I do seem to recall someone who had solar panels on a tow vehicle and used it for the trailer. The wire run would be longer than having the panel(s) on the trailer but other than that I see no reason it would not work OK. Controller near the battery in the trailer would be best also. A charge line seems the better option unless you also want the solar power when you are parked, running a cord from the tug to to trailer.
Old 08-04-2020, 01:44 PM   #30
Trailer: '96 Bigfoot 17'
Yukon
I'm working on my '96 B17 also and talking to Bob. He says he is mixing us up. It seems like he is guiding a lot of people all at once.
What sort of set-up are you doing? The meat and potatoes of mine are as follows:
198 AmpHr AGM Battery (it was free) which required me to remove the fiberglass cowling on the front and put a plastic box on.
300W solar (3x100W renogy panels)
Trimetric SC-2030 and TM-2030
Morningstar suresine 300 inverter (to run coffee grinder (primary need/want as I saw sick of handgrinding) and charge laptops, maybe run a hand blender and charge cordless powertool batteries, bike lights, headlamp batteries (I might get one of those universal DC chargers for some of these duties).
I want to be able to run the furnace, use the lights, and the vent fan without worrying about having enough capacity. These are basic needs, we're not trying to create at home comfort but comfort being on the road for weeks at a time including in the fall when night time temps drop below zero with a baby and toddler. We don't need AC or TVs or anything like that. I feel like our set-up will be sufficient but time will tell. Going to do fixed flat mount panels and tie in some kind of portable panel if it seems like we're not getting enough charge. That way I can place it in the sun if we're camped in the shade (which we will be in the pacific northwest).
It's actually almost done excepting the final stage of drilling through the roof, my anxiety has caused me to leave this until last. After much deliberation I have decided to use 1/4" metal screws. I'll me mounting the panels on bracket fashioned on angle aluminum. I plan to make a small cavity under the food for each screw and fill it with West Systems fiber feinforced epoxy. I'll use 3M 5200 Marine Adhesive under the brackets and cover the top with RV roof sealand of some kind.
I have yet to decide on what to use as a combined box, but I intend to drill a hold on the edge of the roof over the front corner of the bathroom since there is an empty triangular caivty there. The plumbing vent runs up the aft cavity a the same dimension. This will also minimize the length of wire needed as it is right beside the dinette cavity in which all the electrical is located.
Anthony B is offline   Reply With Quote
bigfoot, solar
All new electrical system kyle minor Modifications, Alterations and Updates 4 06-04-2010 11:02 AM
Bigfoot Solar Tim D. Modifications, Alterations and Updates 9 03-22-2010 09:24 AM
New battery- what type for future solar system? LizP Problem Solving | Owners Helping Owners 15 02-26-2009 06:30 AM
can you mix solar system brands? Nancy H Electrical | Charging, Systems, Solar and Generators 2 06-15-2006 07:47 PM
Solar System Advice Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 05-13-2003 10:03 PM
