What is involved in raising our lil Bigfoot? - Fiberglass RV
Old 04-03-2017, 12:16 AM   #1
Trailer: Lil Bigfoot
Hello. We just purchased a lll Bigfoot and are wondering if it is necessary to raise it up? We are doing a big road trip with it, ending up at the tip of Baja Mexico. Has anyone done this and do you have any tips? Not sure where to start, thanks so much in advance!
Julgarneau is offline   Reply With Quote
Old 04-03-2017, 06:09 AM   #2
Jon in AZ's Avatar
Lil Bigfoot has a rubber torsion axle. The answer depends partly on whether the axle is welded or bolted.
The original axle is welded, so it would have to be cut off and a new axle installed with a greater down angle in the axle arms. The Lil Bigfoot has an unusual angled frame design, so some frame modification will be needed to mount a new axle. Cost $$$
If it's a bolted-on replacement axle, you could probably modify the axle mounting bracket to raise the trailer. That will not raise the axle tube, though, only the coach. Cost $-$$
Either way, some custom welding and fabrication on the frame is required. There is no simple bolt-on solution.
As to necessary, I've never been to the Baja peninsula, but I have taken our Scamp, which is probably even lower than your Lil Bigfoot, on some rough back roads a couple of times. With careful driving, nothing bad happened. The trick is taking dips and humps at an angle. The most vulnerable spot is the tongue jack, and you can replace that with a swing-away jack on the side or this adjustable jack: Ultimate Jack
Old 04-04-2017, 12:27 AM   #3
Thank you again very much Jon!
Old 04-04-2017, 03:56 AM   #4
Larger wheels and tires will also raise the trailer.
Old 04-04-2017, 09:42 AM   #5
Hello Jack, thank you for your idea. I wonder if it would accommodate bigger wheels? That sure would be simpler. I will take a photo and post it to see what people think. I see you have a bigfoot although is it a 17 inch? is yours raised? i wonder if ours needs to be...thanks again. any input is very much appreciated
Old 07-31-2018, 11:35 PM   #6
Hi Julie, I came across your post from last year...how did you make out with raising your Lil' Bigfoot?...I have one and am looking to do the same, replace axle and give it a couple extra inches, if at all possible.
AdamB71 is offline   Reply With Quote
bigfoot
What's Involved with Pulling out the Frig and Heater? Archie J Problem Solving | Owners Helping Owners 6 11-26-2009 09:28 PM
Raising 17' Boler sarah j Problem Solving | Owners Helping Owners 0 06-10-2009 03:17 PM
Raising a Bigfoot Peter DBK Modifications, Alterations and Updates 16 09-09-2008 05:06 PM
Raising Bigfoot for more clearance?? Tom Myers Problem Solving | Owners Helping Owners 35 07-06-2007 11:29 PM
Raising a Casita SD16 Steve Rosenberg Modifications, Alterations and Updates 8 11-26-2005 11:54 AM
