Surfside tripple E 1978, torsion axle. - Fiberglass RV
Old 11-01-2019, 11:55 AM   #1
Trailer: SurfSide
Newfoundland
Question Surfside tripple E 1978, torsion axle.
Hello all, I recently purchased a 1978 Surfside tripple E. The thing is a beaut! I suspect that the torsion arms on the axle has surpassed its life tho. The two side sit significantly different over the wheels. I know there is multiple forms on here regarding the correct replacement axle, but I can't see to find a definite answer as to what you people are using in place of the original. Any information is greatly appreciated!
Thank you all in advance!
-Rob
Rob Benoit is offline   Reply With Quote
Old 02-05-2020, 01:19 PM   #2
Trailer: 1977 Triple E
Rob, I have 1977 Surfside with an original torsion axle. I am planning a trip to the North West Territories (from Hamilton Ont.) this summer. Lots of gravel roads! I am assuming that I will need to replace the axle before the trip. I am currently looking to local places (RV& Hitch) that may be able to do this work. I am interested in what experiences other Surfside owners have had? I hope to watch your post for any insights. Bill
William Urie is offline   Reply With Quote
Old 09-16-2020, 03:00 PM   #3
Trailer: Triple E
Hi Rob, did you ever install a replacement?
Rolf Arnold is offline   Reply With Quote
Old 09-16-2020, 03:24 PM   #4
Trailer: SurfSide
Newfoundland
I did. I had a local company build one for me.
Old 09-16-2020, 03:29 PM   #5
+10 I would recommend finding someone who will do the work first. Develop your list of requirements: wheel size, brakes?, additional lift?. Get an accurate weight on your trailer, both the axle weight and overall. Then discuss with who is going to do the work for you.
Old 09-16-2020, 03:31 PM   #6
Trailer: SurfSide
Newfoundland
This is the order form I used. I originally ordered a 10deg up starting angle.
But after removing the old one. I decided to go with the zero deg. rake. And I’m glad I did. The new one bolted right up. As smoothly as silk.
Old 09-16-2020, 03:35 PM   #7
Trailer: SurfSide
Newfoundland
1978 triple e surfside TM1400
Old 09-16-2020, 09:30 PM   #8
Trailer: Triple E
Hey Rob, thank you very much, very valuable information!
One more question: what is your tire size?
Old 09-16-2020, 10:04 PM   #9
David B.'s Avatar
With a Flexi-Ride axle you can change the angle anytime you wish, as when more ground clearance is desired, then lowered way down to store the trailer in a garage.
axle, surfside
How much flex should a torsion axle flex, if a torsion axle could flex flex? JeepScamp Problem Solving | Owners Helping Owners 5 08-10-2014 05:03 PM
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
Tripple e surfside reno. in Winnipeg Jamie Mac Hi, I am.... 9 09-09-2012 05:44 PM
Surf-Side Tripple EEEK james kent General Chat 4 06-22-2008 10:17 PM
torsion axle lifetime? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 17 07-10-2003 07:46 PM
