Best way to Remove old Snap Caps - Fiberglass RV
Old 06-19-2016, 10:25 AM   #1
Trailer: Currently Shopping
Smile Best way to Remove old Snap Caps
Hello!
Jason and I purchased a 2004 13' Scamp. We are fixing a few issues on it and would like to replace the snap caps as some have worn off. How can I remove these without damaging the fiberglass?
Some of the snap caps left behind a little ring of plastic around the plastic washer-any ideas on how to remove this?
Thanks for you your help!!
Crystal and Jason is offline   Reply With Quote
Old 06-19-2016, 03:36 PM   #2
Are you talking about the bottom of the white caps or the clear plastic cup like things the caps snap to.
So for those rings MIA you'll need to drill out the rivets and replace the rivet and the rings. Put a tiny touch of sealer under and in the ring then snap on new caps.
I buy caps for my Casita here, get a hundred caps, they deteriorate fast in the sun and lesser number of bases.
12/12 White Snap-Caps screw caps | Pro-Dec
Old 06-19-2016, 04:34 PM   #3
Originally Posted by Crystal and Jason View Post
Hello!
Just use a thin screwdriver of knife to pry under the edge of the cap. If they are old and weathered they will almost fall apart.
The clear plastic cup under the rivets or screw heads are what hold the caps on.
Pop rivets need to be drilled out, screws can be backed out.
As another said, use a dab of silicone sealant under the cup.
Old 06-23-2016, 10:55 AM   #4
Trailer: Scamp 13 ft
White caps
I just called Scamp a week or so ago and was told the small caps are no longer available. The small ones are used for such as curtain mount rivets. The parts man said they are no longer available from their supplier. Caps used to be available for a 13' or 16 ft with the correct number of each. I ordered for a 16' ( for my 13 ' ) so I would have extras and because shipping is high and about the same for both size Scamps. So now I have a few large caps but no small caps, and Scamp can't supply them. I have tried other kinds of caps but they are not just the same. Maybe someone can suggest other sources. And buy extras, especially in hot or dry climates. David in hot and dry Fresno and Sonora, California
DavidG is offline   Reply With Quote
FREE snap caps Christine P Classified Archives 2 06-16-2009 08:43 AM
snap caps info needed Ricky 4 Problem Solving | Owners Helping Owners 5 02-07-2009 11:11 AM
Best way to Remove Old Body Decals? Kevin A Problem Solving | Owners Helping Owners 4 04-17-2007 07:05 PM
Snap caps and fridge control access Bob Smucker Care and Feeding of Molded Fiberglass Trailers 3 10-17-2006 03:17 PM
How to replace snap caps? Scott Bacon Problem Solving | Owners Helping Owners 17 06-05-2006 08:23 AM
