The time has come for us to say goodbye to our little friend. We are the second owners of this 2011
Scamp 13’.
The original owners bought the
Scamp directly from the manufacturer in Minnesota. We bought the trailer in August 2014.
This is the front bath model. We are asking $8,000.
We are located in Kitsap County, Washington.
You can reach us at
scampforsale@fastmail.com
The trailer was garaged the first 3 years, always winterized in the cold season. It is in very good overall shape, and everything works. There is no external body damage.
Tires are in good shape.
Features of this Scamp 13:
Length: 13'
Exterior Height: 7'6"
Exterior Width: 6'8"
Interior Length: 10'
Interior Height: 6'3"
Interior Width: 6'6"
Super Insulation R15
30 amp power converter
12 volt
lighting with upgraded
LED lights 3-way Dometic
fridge
12 gallon fresh water tank
30 gallon grey tank
9 gallon black tank
Sleeps two, table converts to bed
Clothes closet by door with added shelving
Two-burner
propane stove
Single
propane tank with dual tank conversion equipment included with purchase LED
porch light
12-volt
battery
Custom blue retro curtains
Sink
Two fresh water pumps (one for fresh water, one for the shower drain)
Approximate
weight: 1500 lbs
Approximate hitch
weight: 150 lbs
Hitch ball size: 2"
25 foot 30 amp electric supply cord
Spare tire and cover
Propane 16,000 BTU
furnace with thermostat
Vinyl flooring
Shower package with toilet (wet bath)
10 foot
awning
Electric
brakes (you will need to purchase the controller).
Flat Screen Television (12 volt) with integrated DVD
Screen door
Rear and front cabinets
Cabinets over sink
Silverware Drawer
2" receiver on back end for bike rack
Gas Hot Water Heater 6 gallon
Rear Stabilizer Jacks
External
Solar Power system included -- 45 watt
Battery Meter
Three-Speed Roof Fan
Large opening roof
escape hatch/sun roof
Jalousie Windows (nice when it's raining)
Things we’ve updated:
Replaced
Battery
Replaced door’s foam seal for rubber gasket from Scamp factory
The things that were added after purchase by the original owners:
Flat screen TV/DVD wired into 12-volt system. Cable ready.
Cup holder
Smoke/Co2 detector
Solar Power -- 45 watt external system. Just have to plug the included panels into the trailer. (note: we never used the
solar panels)
Shelves in closet
Extra matching 12-volt LED
light by bathroom door
Electric trailer
brakes
Dual propane tank holder (currently not installed, but included)
Custom vintage curtains
Imperfections: Dinette table is useable, but could be replaced if you desire ($55 from scamptrailer.com). Original owner added a plywood section to the end of the table to maximize the bed size, but has since removed leaving some screw holes. Also, they had a cat door in the bottom of the bathroom door (that didn't work out, the cat hated camping!) They removed the cat door, and trimmed back in the cut-out piece to make the door whole again.
Located in Kitsap County, Washington.
You can reach us at
