Posting bigfoot pictures - Fiberglass RV
Old 05-26-2003, 08:53 AM   #1
After my trip to the coast, I have a bunch of pictures of Bigfoot
travel trailers that I would like to post. When I try to upload them
the system complains that they are greater then 80K. How do I
shrink them to 80K or less to post?
By the way, we saw a 17', 21' and 25' side by side. Wow, really
nice trailers.
- Joe
Legacy Posts is offline   Reply With Quote
Old 05-26-2003, 09:00 AM   #2
Joe, If your pictures are 500 pixels wide (or tall, for vertical shots), 72 dpi (dots, or pixels per inch), and saved in JPEG format (at about 60 percent compression or ''quality'' rate), they should turn out less than 80 k.
You need to use an image editing program to make them fit the above criteria. There are several available (you may even have one that came with your digital camera or scanner). Some use Irfanview. I use Photoshop LE (light edition).
Does this help? We discussed this not long ago on this thread. There's also some info in the Website Tutorials section of the Forum.
Old 05-26-2003, 09:01 AM   #3
Joe:
Just resize to 500 pixels wide and you should have no problem posting them here. If you've taken high res pictures then you will have to lower the DPI.
Irfranview is a great software program (free too) if you need one.
Old 05-26-2003, 06:23 PM   #4
screen shot
Joe, if you are using Photoshop le which, incidentally ships bundled with some of the better digital cameras, check this pict for the path to image size adjustment. The yellow highlights the pict at 100% [bottom left] @ full display size and the two boxes where you can vary the pixel size.
When you vary one field the other adjusts automatically. I find 400 X 300 is just fine for this board.
<img src=http://www.fiberglassrv.com/board/uploads/3ed2afcdbb671screen copy.JPG/>
bigfoot
Posting pictures Forum Admin, News & Announcements 7 12-31-2010 01:10 AM
posting pictures Christi W Forum Admin, News & Announcements 8 02-29-2008 10:30 AM
Hey, Roger! Where's the pictures of your Bigfoot? Gigi General Chat 9 06-20-2006 03:21 PM
Lots of Bigfoot pictures (and comments) Legacy Posts General Chat 6 05-29-2003 05:18 PM
posting pictures General Chat 0 01-01-1970 12:00 AM
