Quick Straightforward Trillium tail light refit - Fiberglass RV
Old 11-20-2016, 05:29 PM   #1
buk
Trailer: Trillium
The LED crowd can just ignore this one.
Super simple refit for your old Trill. $8.99 common 3 wire 12V trailer lamp from Pep Boys or wherever.
Remove stock Trill guts
Unscrew and remove red lens from top and side of new lamp
Trim closed side if you wish
New case fits snug inside Trill lense and lays flat on old base. Bulb is enclosed in glass, so waterproof on its own. Throw a retaining screw in if you want.
Fin
Will throw up lit pics later in the week
buk is offline   Reply With Quote
Old 11-21-2016, 10:46 AM   #2
Trailer: Trails West Campster andTeardrop American
And for you LED enthusiasts, there are 1156 and 1157 replacement bulbs with glass envelope and contains led's in place of the usual wire filaments. I think other bulb equivalents are available too. Not cheap, but LED!
rwilhelm is offline   Reply With Quote
Old 11-22-2016, 11:30 AM   #3
Trailer: Trillium
For our Canadian members, Princesses Auto sells the LED version for a reasonable price and it is such a simple retrofit that I would encourage others to consider it.. Reasonable price, simple installation process and greater viability for the folks following you.....
Chris from Comox..
Chris from Comox is offline   Reply With Quote
Old 12-12-2016, 10:34 AM   #4
Name: Billy Sharpstick
Trailer: Scamp 13 - 2005
One potential problem with replacing incandescents with LEDs is that the old fixtures are designed for a point source glowing wire. Many LEDs will fit, but they may have optics that are directional and, although are brighter, do not focus their light properly on the reflector back of the light assembly. They will work, but you are better replacing the whole assembly.
sharpstick is offline   Reply With Quote
Old 12-12-2016, 11:14 AM   #5
Sharpstick. You may be right. The photo I saw online, had about 30 or so very small led arranged barrei like in 5 or 6 bands, the effect being to throw light in virtually all directions. But the only way to for sure would be to try one. I may be wrong but the price I remember was around $15. Since my new tailights came with bulbs, I didnt dig any deeper. Check twice, buy once or something like that. 😃😃😎
Sent from my SM-N920V using Fiberglass RV mobile app
Old 12-12-2016, 12:42 PM   #6
cpaharley2008's Avatar
Remember if you are replacing outside tail and marker lights you will need colored bulbs as the lens is inadequate to meet DOT requirements with a white led bulb.
Jim
Never in doubt, often wrong
Old 12-12-2016, 12:55 PM   #7
Right again. My replacement lights (non led) are colores lenses, so not a problem. I believe the led I looked were available in both amber and red
But thats from memory. I will do some searching and get back here with a link.
Just so you'll know, I aint sellin em 😃😃
Old 12-12-2016, 01:32 PM   #8
Here is a link that I found when researching tail light replacement for Hampster the Campster.
https://www.superbrightleds.com/cat/tail-brake-turn/
My estimate (memory) for price was about right and they are available in amber and red. My estimate (lack of memory) of the number of leds is a bit off, however they do give the lumins for comparison with standard bulbs.
Please remember: I'm an old fart not an LED salesperson ....... never was actually.
Roger
light, trillium
Surfside Refit Saga peterh Modifications, Alterations and Updates 50 06-12-2019 04:46 AM
My surfside refit Sandy St.Louis Modifications, Alterations and Updates 2 07-06-2014 10:55 PM
Boler Refit video series Peter Knowles Modifications, Alterations and Updates 9 05-03-2014 08:21 AM
My refit of a Freedom Jetstream BigAl Care and Feeding of Molded Fiberglass Trailers 9 11-04-2013 07:49 AM
Pictures of our 1983 13' Scamp after our refit Evergreen Modifications, Alterations and Updates 24 06-06-2011 07:49 PM
