Fantastic Fan on Trillium install - Fiberglass RV
Old 01-27-2017, 08:23 PM   #1
Trailer: Trillium
I'm in the middle of installing a Fantastic Fan in our Trillium 1300 with a riser. I thought it would be cool to use insulation foam to shape my own. Definitely not the easiest way but I'm excited for the end result. So I formed the foam down to what I need and drilled holes in it for the 1/4" lag bolts that'll I'll run up through the camper roof then bolted down on the fan flange. I then coated the foam with waterproof wood glue and will fiberglass it, overlapping onto the roof itself. A couple questions, should I use butyl tape between the foam and roof and how much do I need to sand the roof down to apply fiberglass to it?
Name:	ImageUploadedByFiberglass RV1485569453.190859.jpg
ID:	102496Click image for larger version
Name:	ImageUploadedByFiberglass RV1485569473.608638.jpg
ID:	102497Click image for larger version
Name:	ImageUploadedByFiberglass RV1485569499.315520.jpg
ID:	102498Click image for larger version
Name:	ImageUploadedByFiberglass RV1485569518.657082.jpg
ID:	102499Click image for larger version
Name:	ImageUploadedByFiberglass RV1485569535.799631.jpg
ajdemo76 is offline   Reply With Quote
Old 01-28-2017, 10:43 AM   #2
Trailer: Outfitter truck campper
I can't answer your question but I sure do like the way you went about this. Looks like you'll have a beautiful result when all finished. Nice job!
TomandCallie is offline   Reply With Quote
Old 01-28-2017, 12:28 PM   #3
Gilles's Avatar
Quebec
Why you did not use the supplied adapter with the installation kit.
Your installation looks nice but, from what I see it will be much higher than normal.
Can you install a Maxxair over this installation?
Gilles
Bigfoot 25B21RB.
Gilles is offline   Reply With Quote
Old 01-28-2017, 12:34 PM   #4
Gilles's Avatar
Quebec
You can probably find the answer in these conversations :
Fiberglass RV - Search Results
Gilles
Bigfoot 25B21RB.
Old 01-28-2017, 12:46 PM   #5
Trailer: Trillium
Hey Gilles,
Yea, I originally made the riser too tall so I shaved it down which you can see from the side profile on one of the last photos. I basically made it so i can get it as low as possible without having the control knob in the way. That explains why I'm keeping the fan level. I didn't have a riser in the fan kit I bought. What does it look like? Either way, I think this will turn out alright. Our big thing is clearance since we keep this in the garage. Installing the fan as I plan, it'll give me another 4" of clearance to work with for when we replace our axle. Not that I'd raise it that much, just nice to know the room is there.
Old 01-28-2017, 01:00 PM   #6
Trailer: G30 Elite Class C
Gilles I have to agree with you to use the Search engine but no one,
:seems to think of this before hand?
Stude
Old 01-28-2017, 02:28 PM   #7
Gilles's Avatar
Quebec
This part should be part of the installation kit, installs inside and the fantastic fan connects with this one.
With my Trillium it was too high because the ceiling of the trailer is thin, I cut the surplus with a good saw finishing, it is plastic, we must work patiently:
Gilles
Bigfoot 25B21RB.
Old 01-29-2017, 08:37 PM   #8
Trailer: Trillium
Yep, I do have that trim piece. I'll cut it down and install it once I'm done with all of the fiberglass work and install the fan.
Old 01-29-2017, 09:18 PM   #9
Trailer: Trillium
Stude
I did, but the search function never seems to work for me. I usually search "fiberglassrv" then whatever topic on Google, but I couldn't find any threads that answered my question.
Old 01-30-2017, 12:08 AM   #10
Borrego Dave's Avatar
Nice job Andy, looks very good.
Old 01-30-2017, 04:59 AM   #11
Trailer: Boler 13 ft
as far as the butyl tape it wont hurt and as far as the sanding I would sand the gel coat off and use the West System Epoxy/Resin fiberglass.
I built canoes and have used this product for years and have had nothing but good results.
Old 02-01-2017, 07:30 PM   #12
Clayton's Avatar
Trailer: 1975 Trillium
Hey Andy, I like your idea. I will be curious to see how it turns out. When I did the install on my MaxxFan, I made a fiberglass riser out of square tubing. I did a light sanding on the roof around the opening and then used marine epoxy and also used 3 rivets per side. When I mounted the base to the riser I used butyl tape and rivets. I finished it off with some Dicor sealant. Absolutely no leaks and super solid.
Name:	ImageUploadedByFiberglass RV1485998989.447435.jpg
Clayton is offline   Reply With Quote
Old 02-01-2017, 10:01 PM   #13
Trailer: Trillium
That looks good, Clayton! And a lot less work... We briefly looked at those fans but the clearance isn't there for the garage.
I'm currently in the middle of sanding the gel coat so the fiberglass has something to bond to. My goal is to fade the riser into the camper so it looks like a factory job but this is my first time working with fiberglass so we'll see. I'll post some photo updates this weekend. I haven't even begun to research how I'd color match this thing.
Old 02-03-2017, 04:25 PM   #14
Trailer: Trillium
ID:	102615Click image for larger version
ID:	102616Click image for larger version
ID:	102617Click image for larger version
Finished sanding the gel coat today, put down a layer of butyl tape, bolted down the foam and put down the first layer of fiberglass, sanded after curing and then did the second fiberglass coat. The fun part of bondo and sanding is next. [emoji52]
Old 02-04-2017, 04:37 AM   #15
Looking good
Old 02-22-2017, 08:12 PM   #16
Trailer: Trillium
ID:	103202Click image for larger version
First pass with bondo and the sanding begins... My time to work on this has been limited with other things going on as well but i just need it done by the end of March.
Old 02-23-2017, 12:19 PM   #17
Clayton's Avatar
Nice work. Can't wait to see the finished product.
Old 03-23-2017, 08:53 PM   #18
Trailer: Trillium
ID:	104252Click image for larger version
ID:	104253Click image for larger version
So other than cutting off excess butyl tape, caulking, wiring it up and minor interior details, I'm just about done. I couldn't find even a close color match from Fibreglast so I just went with white paint. I also got a little tired of sanding so it's not exactly a showroom finish but oh well, nobody is going to see details without climbing up there! Most importantly, we have the interior clearance and with all the lag bolts and fiberglass, I don't think it's going anywhere. [emoji1]
Old 04-02-2017, 05:06 PM   #19
Trailer: Trillium
Finally sealed and done. Hoping to get it out within the next week or two.
Old 04-02-2017, 05:30 PM   #20
Sweet install! Does the air deflector have any effect smoothing out the airflow?
trillium
Fantastic Fan a little bit less fantastic Davie B Problem Solving | Owners Helping Owners 10 05-15-2013 04:25 PM
Fantastic fan flange install Pat C Problem Solving | Owners Helping Owners 8 07-05-2009 09:43 AM
Fantastic Vent vs. Fantastic Fan Ami P Care and Feeding of Molded Fiberglass Trailers 5 06-30-2008 11:33 AM
Fantastic Fan Install - switch to change air flow? Kurt in BC Problem Solving | Owners Helping Owners 29 11-11-2007 05:58 PM
Fantastic Fan install questions TonyL Problem Solving | Owners Helping Owners 18 02-28-2006 07:59 AM
» Trailer Showcase
Purl
Maud
Lilly
Antonia
