Modern Atwood furnace in Trillium - Fiberglass RV
Old 04-03-2017, 10:49 AM   #1
dleverton's Avatar
I've given up on the old beater Duotherm furnace. Since putting in the Queen size bed, lighting the pilot light has become a chore best left to an acrobat. The Atwood fits perfectly and has electric start.
Name:	ImageUploadedByFiberglass RV1491238091.799363.jpg
ID:	104649Click image for larger version
Name:	ImageUploadedByFiberglass RV1491238121.718864.jpg
Doug
Doug
dleverton is offline   Reply With Quote
Old 04-04-2017, 10:19 AM   #2
trilliumdon's Avatar
Trailer: 1975 BIOD Extase
Wow, interesting. More info neeeded!! It looks like this is on the right rear side where the original water tank went.... which model is it? Are you venting to the side or rear of the trailer? How did you anchor it? Etc, etc....
trilliumdon is offline   Reply With Quote
Old 04-04-2017, 11:00 AM   #3
dleverton's Avatar
Mine is a 1973 1300 same as yours, but for some strange reason it was originally built with the water reservoir on the kitchen side and the furnace was on the curb side. I used the original DuoTherm exhaust fitting on the curb side, but had to modify it slightly, because on the Atwood in and out are not coaxial, see picture. Also the exhaust vent is in a different location.
Name:   ImageUploadedByFiberglass RV1491324624.002349.jpg
The rest was just mounting 3 4" vents inside and insuring there was sufficient cold air return. I mounted it with angle brackets to the original furnace platform.
It is a larger unit (30,000btu) than I would have chosen had I choice (found it on kijiji), but I'm very pleased with how well it works. It just runs on a lower duty cycle than a 15,000btu unit would, and in 2 minutes the place is warm. It draws 6.7A while on, nothing while off, so the lower dutycycle means it is on half the time a 15,000btu unit would be on, so average current consumption is half. Heats faster, Watt/Hour consumption less.
It's sweet.
Doug
Doug
Old 04-04-2017, 02:06 PM   #4
Do you have it on a thermostat or do you just fire it up on occasion? I've found they can be pretty noisy if they come on in the middle of the night. Any issues with that end of the bed getting unmercifully hot? Many questions!
Old 04-05-2017, 12:14 AM   #5
dleverton's Avatar
I do have a thermostat, an old one with the mechanical anticipator. I haven't slept with the unit as yet, but it seems no noisier than the DuoTherm. It has little but air noise like a domestic air mover. There is a wooof on ignition. I don't anticipate hot spots as there is a lot of air movement and the hot air comes out from under the bed, so takes a circuitous route to where we sleep. Also half of the cold air return is a grill right by the door, and half is from the front of the trailer just below the stove where the front settee used to be, and that air flows under the sink, past the water reservoir and through the chamber at the back of the trailer where the rear table hooks used to be. So the hot air goes to the front of the trailer first and there is a real mix of air. I don't notice any hot spots (unless you were to crawl under the bed). We don't usually camp in winter, and the thermostat is right at the head of the bed, so we will turn it on to heat the place, and then off for the night. I went out there tonight, crawled onto the bed and turned it on and everything just got warmer. This coming weekend I'll be camping in it for three nights.
Doug
Doug
Old 05-11-2017, 07:01 PM   #6
dleverton's Avatar
I've used the furnace on some chilly nights and I have no problem with it being 30,000 BTU. The trailer heats up fast (half the time of the old duotherm), and the duty cycle is short, so on 3 min, off 12.
Doug
Doug
furnace, trillium
Trillium Sleek and Modern Update crewguy72 Modifications, Alterations and Updates 23 01-11-2015 05:44 PM
Problem with Atwood furnace JPraeder Problem Solving | Owners Helping Owners 8 06-06-2013 06:30 PM
Atwood furnace new on Trillium..won't kick on...fuses fine.... lloyd cicetti General Chat 15 04-12-2010 08:21 PM
Battery power for an Atwood Furnace Mac B Problem Solving | Owners Helping Owners 29 12-03-2009 01:00 AM
