Please help with door/seal issues on Trillium 73' 1300 - Fiberglass RV
Old 04-25-2017, 06:16 AM   #1
Trailer: In the market
Alabama
ID:	105289Click image for larger version
ID:	105290Click image for larger version
Not sure how to fix the door. Stripping was coming off at the top so we replaced it and then had a difficult time shutting the door as it would squish the stripping. Hinges seem okay. If you look at the pictures of the outside, the gap in the door gets wider at the top. We are new to this, any input would be appreciated. Thanks in advance!
Martine is offline   Reply With Quote
Old 04-25-2017, 09:37 AM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Originally Posted by Martine View Post
Attachment 105289Attachment 105290Attachment 105291
Not a Trillium owner, but it appears your hinges may be quite worn - the screws don't line up any more.
Charlie Y
Old 04-25-2017, 01:41 PM   #3
Door fit
The doors on all of these are poor as it is on mine. Hinges you can get nice ones on line at lee valley the around $ 26.00 cdn for 2 . on the surffside ones like mine the bottom body line is 2" out.every one i looked at in person or on line are the same .Happy trails
Old 04-25-2017, 04:07 PM   #4
Raz
Raz's Avatar
Trailer: Trillium 2010
The Trillium hinge is a rare beast. They used a commercial refrigerator hinge made by a company called Kason. Kason is still in business but their model No. 139 with a 3/8" offset is tough to find. I found a spare set at McMaster Carr, part no. 1276A52. They might have them? Trillium Outback in Canada has them. Trilliumrv lists them as well. One member found a set with zero off set on ebay and added a spacer. Unfortunately anything found at the hardware store will require a lot of improvising.
Measure between the upper and lower screws. They all should be the same. If not, your door may need resetting. Many were screwed into a piece of wood in the wall of the trailer that rots over time.
trillium
Trillium 1300 door issues Tom Jefferies Problem Solving | Owners Helping Owners 5 05-31-2016 02:22 PM
Trillium 1300 Bargman latch wear / door issues FlatlandFlyFisher Problem Solving | Owners Helping Owners 2 08-31-2015 03:18 PM
Trillium 1300 Door Seal or gasket replacement Irene Problem Solving | Owners Helping Owners 1 07-17-2014 07:32 AM
window on scamp door seal help needed PLEASE Red Fox Care and Feeding of Molded Fiberglass Trailers 1 06-10-2014 04:27 AM
Trillium 1300 Rubber Door Seal georgia g Problem Solving | Owners Helping Owners 0 07-28-2009 05:51 PM
