Removing non original paint from Trillium - Fiberglass RV
Old 05-01-2017, 05:45 PM   #1
Trailer: '79 Trillium 4500
I recently obtained a 1979 Trillium 4500 in New Mexico. The trailer was originally titled there so it seems to be in great shape. However, instead of replacing the decal striping w/ new decals, the original owner painted stripes and it wasn't done all that well as there is some bleeding through where it was masked off. Any suggestions as to how to remove the paint. I'm sure it was applied with a spray can. I have a heat gun, have stripped plenty of furniture w/ stripper.., But I have never worked with fiberglass before and I don't want to harm the fiberglass. I'm not sure if I'll just remove the striping and leave it without striping or remove and then purchase decal stripes. I suppose it will depend how it looks after the I get the stripes removed. Thank you in advance for any tips.
34Roy is offline   Reply With Quote
Old 05-01-2017, 06:05 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
John, congratulations on your recent acquisition and welcome to the forum!
My DW used a heat gun on low setting to remove much of the decal stripe on our 4500. She was careful to keep the heat gun moving and used a plastic scraper. We tried metal scrapers, etc, but they tend to damage the gelcoat.
You could try the heat gun. Others on this forum have also had success with fiberglass-specific paint strippers. Still others have removed paint from gelcoat using just a 3M purple pad (EDIT: purple pad with lots of water).
When we removed the stripes, a shadow was left. Surprisingly, we were able to mostly get rid of the shadow by applying bar keepers friend with a soft cloth where the stripe had been removed.
Good luck!
Old 05-01-2017, 07:13 PM   #3
Thank you the reply, I didn't realize there was stripper specifically for fiberglass. BTW, I'm also a John from Michigan. My 34Roy name is taken from my 1934 Gibson Roy Smeck guitar that I play, also made in Michigan, Kalamazoo that is.
Old 05-01-2017, 07:50 PM   #4
Sweet guitar!
paint, trillium, vin
Original Boler Paint Colors khite Modifications, Alterations and Updates 32 12-13-2023 08:32 PM
paint to match original Boler colors Peggy Care and Feeding of Molded Fiberglass Trailers 18 08-28-2018 11:43 AM
Does anyone know the original 71 Trillium colors? And how can I safely strip paint? coalminecanary Modifications, Alterations and Updates 18 06-21-2012 11:27 AM
Removing paint from fiberglass Angelo F. Problem Solving | Owners Helping Owners 13 09-07-2010 04:15 PM
removing paint from Boler outside Judy Powell Problem Solving | Owners Helping Owners 1 07-10-2007 11:01 AM
