Loose Door Hinges on Trillium - Fiberglass RV
Old 05-08-2018, 09:53 AM   #1
Corinne L's Avatar
Name: Corinne & Michael
Trailer: Trillium 4500
How can I repair edge of door where the hinges are attached? The screw holes are loose.
How to reinforce? Any products out there?
Corinne L is offline   Reply With Quote
Old 05-08-2018, 11:31 AM   #2
David Tilston's Avatar
I would fill the hole with a mixture of white glue and saw dust, or a wood match stick, (not the hot end)
Old 05-09-2018, 09:12 AM   #3
I would use an epoxy adhesive to redo the holes. Do a little research and you will find certain epoxies get hard enough to machine. Something like JB Weld or Loctite.
Lee
Captleemo is offline   Reply With Quote
Old 06-18-2018, 07:36 PM   #4
Trailer: Trillium
Confusion
I just did that on my Trillium. I used hardwood splints and fibreglass resin. I cleaned up the hole a bit, then got some hardwood and split it into pieces that would fit into the holes. I dipped the sticks in some resin and tapped them into the holes. 24 hours later everything was solid. I trimmed and sanded and then drilled new holes for the door. It fits like it's 10 years old instead of 40.
Sturmey is offline   Reply With Quote
trillium
Replacing 1974 boler hinges with new scamp hinges ArneB Modifications, Alterations and Updates 2 08-10-2015 12:39 PM
Loose door glass The Minimalist Care and Feeding of Molded Fiberglass Trailers 7 06-09-2013 07:01 PM
