09-25-2015, 10:41 AM
#21
Trailer: Scamp 16
Originally Posted by honda03842
[B]Steve These are our Kitchen Drawers. The one in front of the sink is a tilt out drawer. There is a white basket on the back of the drawer front. It contains our toothpaste and two electric toothbrushes.
The drawer on the right is a pull out drawer and contains dishtowels, an apron and ... It is counter depth.
Thanks Norm and Ginny, I looked thru part of the other thread and saw all the pictures. When I have more time, I'll look further. You've done a great job and thank you!
09-25-2015, 10:46 AM
#22
Name: Norm and Ginny
Trailer: Scamp 16
Under Stove Pantry
Steve, We have an under stove pantry, each about two feet deep primarily used to hold canned goods. These heavy items are near the axle and low in the trailer. The pull out shelves make it easy for Ginny to find things, they are basically over the wheel well. Below them and in front of the wheel well is a blastic bin that holds onions and potatoes,
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
09-25-2015, 10:47 AM
#23
Trailer: Scamp 16
Steve, I took pictures of everything a few minutes ago. If you want anything let me know.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
09-25-2015, 11:42 AM
#24
Hello, STEVE L.
Quando omni flunkus, moritati
Could you please translate? something like what, something like "all,"something like fails, something like death or mortality?
thanks!
09-25-2015, 11:54 AM
#25
Steve L:
#26
Steve L, please correct my translation: When all fails, die. when all else fails, give up.
Kai in Seattle
09-25-2015, 02:13 PM
#27
Trailer: Class A Motorhome
Don't think that I have ever seen an RV fresh water tank that was exposed to any sunlight. Most (of not all) are usually inside the coach.
But that's a good lesson as to why they are inside.
09-25-2015, 03:36 PM
#28
Steve, on my Boler I took moving the fresh water tank outside to the extreme.
Here is the details External Water Reservoir
09-30-2015, 07:05 AM
#29
It's pseudo Latin, from the Red Green show, alledgedly meaning "when all else fails, play dead."
Without adult supervision...
Quando omni flunkus, moritati.
Also,
I'm a man, but I can change, if I have to, I guess.
09-30-2015, 09:40 AM
#30
How could it be pseudo-Latin if it's from the Red Green show? Didn't he invent Latin?
09-30-2015, 11:41 AM
#31
Trailer: Boler 1975
Email
Steve I'm struggling with the same issues that you are. I removed my tank from under the seat/table area. The tank is in great shape but considering it dates back to 1975 I'm thinking its time to replace it. I do lean towards Ian's setup for many of the reasons discussed here.
The original tank was held tight against the bottom of the trailer with a sheet of 3/4" plywood and fastened with bolts. Seemed to work well.
The tank I removed is about the same dimension as the one you are considering.
This is the only wood that held the tank tight against the underside of the Boler.
09-30-2015, 12:54 PM
#32
Hi! Say, thanks! Wasn't far off, just missed the "play" aspect of "moritati." My husband uses this strategy quite a bit...I must seem like a grizzly or something.
Kai in Seattle
10-28-2015, 08:55 AM
#33
Trailer: Scamp 16
Hi Ian,
I'm thinking about doing this. I've got an electric pump and am wondering if on of the outside city water connectors with the back flow valve will work. Will the little pumps have enough suction to open it. It's probably just a metal and spring in there. Kinda like this: Valterra A01-0170LFVP White 2-3/4" Plastic Lead-Free Flange Water Inlet. Thoughts? Thanks, Steve
10-28-2015, 09:20 AM
#34
The pump has to draw air then water to prime and run and it doesn't have that kind of capability as does the pressure side. I'd doubt if it could draw enough to overcome what is, basically, a pressure valve.
I used a standard RV drain fitting with a male hose fitting for my external tank./
10-29-2015, 07:23 AM
#35
Trailer: Scamp 16
Thanks Bob. After looking some more at the current set up (diner tore out right now, need to replace floor due to water damage) I believe the pump has a back flow regulator so a drain on the outside like has been suggested should work.
10-29-2015, 09:29 AM
#36
RV water pumps, in a pressurized system, have to have a backflow valve, otherwise they couldn't hold pressure and would run continually.
