hitch height for scamp 16? - Fiberglass RV
Old 04-15-2016, 08:36 PM   #1
Trailer: 2001 Scamp 16 layout 3
Question hitch height for scamp 16?
Scamp salesman told me to set up my hitch height at 17-18" despite scamp booklet listing apx. height of 21". He said booklet is wrong and said 17" is probably best for better gas milage plus for a 2001 trailer whose suspension would be sinking. I grilled him on this and he stayed firm. I suggested that he might be thinking of a scamp 13 but he insisted on this as the best height for a 16. Is this true? What height do others run at?
denny w is offline   Reply With Quote
Old 04-15-2016, 11:57 PM   #2
Byron Kinnaman's Avatar
The best hitch height is the one where the trailer pulls level, if not possible a slight nose down is ok,
I suggest that you go with 17 to 18" height the adjust if needed. Draw bars are pretty cheap.
Old 04-16-2016, 04:38 AM   #3
Best hitch height is individual to each trailer based on age, tires and axle. Nothing is written in concrete. What you need to pull level or slightly nose down on your trailer?
Old 04-16-2016, 05:25 AM   #4
21 is way too high, I settled with 18 and it works out level and tow smoothly.
AC
achang001 is offline   Reply With Quote
Old 04-16-2016, 06:31 AM   #5
Originally Posted by achang001 View Post
21 is way too high, ...
If I recall right, mine is at 20 7/8 inches high* before the trailer is hooked up. The trailer causes the tugs rear end to drop about one inch. This results in a near perfectly level trailer.
Guess you won't know until you get there, but you should be able to get close and then fine tune it as needed.
* this is to the TOP of the ball.. make sure we are talking apples and apples.
Old 04-16-2016, 08:37 AM   #6
I would be glad to offer an opinion, but I replaced my axle with a Flexiride and 14" wheels and tires so that I could adjust the ride height to fit my VW.
Mine comes out to about 18" after I have used the airbags to level the car.
Hitch height on 5th wheel scamp Jamesbucklin Problem Solving | Owners Helping Owners 6 03-28-2016 08:30 AM
Scamp 16' Hitch Ball Height semievolved Problem Solving | Owners Helping Owners 28 02-26-2016 12:03 PM
Scamp 13 hitch height 16-18" means... CampyTime Towing, Hitching, Axles and Running Gear 18 06-15-2015 04:52 AM
Scamp 13 Hitch Height arashaw Towing, Hitching, Axles and Running Gear 20 05-14-2013 07:09 PM
Hitch height? Legacy Posts Towing, Hitching, Axles and Running Gear 3 02-11-2003 03:55 PM
