1977 Surfside Restoration - Brakes - Fiberglass RV
Old 07-09-2018, 06:43 AM   #1
Trailer: Triple E Surfside
Need to determine if original brakes are 7" or 10". I am purchasing an entirely new torsion axle assembly w/ drums and electric brakes. Thanks!
dchoile is offline   Reply With Quote
Old 07-09-2018, 08:31 AM   #2
Trailer: 1969 Boler 13'
Have a measuring tape handy?
https://www.etrailer.com/question-223638.html
Al
Gippeto is offline   Reply With Quote
Old 07-09-2018, 08:40 AM   #3
Was hoping not to have to take the drums apart to measure, which I will do as last resort since I cannot get to the axle for three weeks. Thanks for the tip!
Old 07-09-2018, 09:02 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Once you get access to your old brakes, it should be easy to determine. I have a set of Dexter 10" brake drums on the shelf. They are about 10.5" outside diameter at the widest point. 7" brake drums are probably about 7.5" outside diameter at the widest point.
You could get away with ordering 10" brakes as long as the drums fit inside the back side of your wheels. From the photo they look more like 7" brakes.
Old 07-10-2018, 02:33 PM   #5
David Tilston's Avatar
Daniel, What do you plan to do with the old brakes?
Old 07-10-2018, 06:20 PM   #6
No plans. You interested in them? Shoot me a private message if so.
brakes, surfside
1979 surfside restoration David D Modifications, Alterations and Updates 0 05-06-2017 12:23 PM
1977 Scamp restoration project Celeste Modifications, Alterations and Updates 25 04-25-2012 07:42 PM
1977 Scamp 13 Restoration Project ReilleyS Modifications, Alterations and Updates 29 05-14-2011 02:22 PM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
1977 Amerigo Restoration Gerry Modifications, Alterations and Updates 4 11-01-2006 06:39 PM
