1977 Surfside Restoration - Window Repair / Replacement - Fiberglass RV
Old 08-14-2018, 07:40 AM   #1
Trailer: Triple E Surfside
Hi Surfside community,
Looking for tips/recommendations to help w/ my decision on replacing the front 15x42 window. The glass broke on one side and I am having a tough time finding replacement windows. Pics attached. Willing to either replace the glass and keep the frame or buy a whole new window.
dchoile is offline   Reply With Quote
Old 08-14-2018, 09:38 AM   #2
Bob in Mb's Avatar
Trailer: Surf-Side
Manitoba
I am sure that others will have ideas on where you can source a window. I just wanted to make a comment based on camping in a Surfside. Please replace your window with one that opens. One big advantage of the Surfside is that windows open on all 4 sides giving the best air flow. Having just camped two nights in the extreme heat of the last few days, that air flow is a big deal!!
Bob in Mb is offline   Reply With Quote
Old 08-14-2018, 10:46 AM   #3
Trailer: Boler 1700
DH went to a local glass place to have to 2 new radius panes cut and mounted in our existing window for the boler. We researched and found any needed window gaskets.
And I heartily agree about keeping opening windows, that is what I love about our Trillium.
Lisa in Michigan is offline   Reply With Quote
Old 08-14-2018, 10:56 PM   #4
Trailer: 1969 Boler 13'
Glass panes are easily and inexpensively replaced. Any glass shop worthy of the name can cut them.
For that matter...cutting sheet glass is REALLY easy to do.
Al
Gippeto is offline   Reply With Quote
Old 08-15-2018, 12:24 AM   #5
Borrego Dave's Avatar
NO,NO,NO Dan, never use regular sheet glass on any kind of vehicle, tempered glass only. You have flat glass which makes it a piece of cake to have made up.
Old 08-15-2018, 04:04 AM   #6
Trailer: Trails West
You can also use polycarbonate for treplacing the panes. Using polycarbonate is important, don't use the less expensive acrylic plastic as it is more prone to fracturing and scratching. It is also a good choice because polycarbonate is easier to cut with a table saw, jig saws and routers.
Old 08-15-2018, 07:42 AM   #7
Thanks for the heads up on the sheet glass. I prefer to have someone set it for me so will talk to local glass suppliers about having them install it since I don't know how to take the thing apart, which gaskets to buy and how to properly install and seal it.
Old 08-15-2018, 09:22 AM   #8
Tempered glass cannot be cut ..perhaps you meant safety glass? Not all glass shops will carry that in sheet form...better odds in an agricultural area.
Polycarbonate is very impact resistant, but is also very soft and scratches VERY easily.
Having used polycarbonate and acrylic over the years, acrylic machines much better.
When in doubt, bounce the question off the fellow in the back of the glass shop.
Al
Old 08-18-2018, 09:06 AM   #9
Hi last year I removed and replaced all the windows (including plywood backing trim) in a 78 Surfside. I could share the photos and techniques if you want them. I agree with the other members to replace the pane only.
David D is offline   Reply With Quote
surfside
1977 Surfside Restoration - Fibreglass Shell dchoile Modifications, Alterations and Updates 6 08-13-2018 10:27 AM
1977 Surfside Restoration - Brakes dchoile Modifications, Alterations and Updates 5 07-10-2018 06:20 PM
79 surfside window replacement David D Problem Solving | Owners Helping Owners 1 06-11-2017 11:11 PM
Best Repair/Restoration Work in OR?? Anna G Care and Feeding of Molded Fiberglass Trailers 0 05-16-2017 04:26 PM
Boler Repair/Restoration Shannon MacNeill Problem Solving | Owners Helping Owners 0 06-29-2015 11:16 PM
