Replacing front parking lights on casita - Fiberglass RV
Old 07-18-2009, 09:07 PM   #1
Trailer: Casita Patriot Standard 13 ft
I don't think you have to have a casita to answer this question.
My front parking lights on the camper need replaced. The contacts have corroded as such that lighting function is intermittent. I have the replacement part (I'm replacing the little assembly that holds the light bulb), but I can't for the life of me figure out how to remove the two grommets that affix the light fixture to the trailer. it isn't a phillips screw or anything, just a round grommet with a round opening in the center.
If you don't know what I mean, I'll post a picture later.
Adam S. is offline   Reply With Quote
Old 07-18-2009, 09:54 PM   #2
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
It's a pop rivet that has to be drilled out but wait for someone here to tell you the drill size because i'm not sure.... but it is definately smaller than the cap size on that rivet. When it's out just pop rivet another back in to hold in place.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Joe Z is offline   Reply With Quote
Old 07-19-2009, 06:55 AM   #3
Trailer: Casita 17 ft Spirit Deluxe
I replaced all of the running lights on our Casita shortly after purchasing it in 2004.
The process is quite simple:
1) Drill out the old pop rivets
2) Splice new wires to old wires
3) Puss splices and wire back into the hole
4) pop rivet back into place
The pop rivets are 1/8 inch dia. and 1/2 inch long. You should use a 1/8 inch drill bit to remove the old rivets.
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 07-19-2009, 09:43 AM   #4
Sounds simple. Okay, so it looks like i need to buy some pop rivets. After the olds ones are drilled out, they are useless and disposed of, correct? Does one need a "rivet gun" to install a new rivet?
Old 07-19-2009, 12:36 PM   #5
curtis c's Avatar
Trailer: 1994 Lite House
yes, you need a rivet gun.
curtis c is offline   Reply With Quote
Old 07-19-2009, 01:36 PM   #6
pjanits's Avatar
Trailer: 17 ft 1986 Burro
I would also schmooze some butyl tape in those holes (wires and rivets) to keep out water.
pjanits is offline   Reply With Quote
Old 07-19-2009, 07:00 PM   #7
Make sure when you purchase one that installs 4 different size pins.
Just ask at Home Depot/Lowes.
Old 07-21-2009, 09:07 AM   #8
If you want to replace the entire housing, check out this site... there's LED replacement housing/lenses on the site too... further down on the referenced page.
RV Lights & Lenses
casita, lighting, lights
Replacing the front window... Scamp 13' Matthew Lyon Problem Solving | Owners Helping Owners 31 06-23-2013 06:59 AM
Replacement Tail Lights, 1987 Casita 16' LD DayTripper Problem Solving | Owners Helping Owners 5 08-10-2009 10:53 PM
Replacing the Front A/C on a Casita Joe Z Problem Solving | Owners Helping Owners 5 07-07-2008 03:15 PM
Notes on replacing the front AC in a Casita 16’ Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 03-28-2003 05:09 PM
