My ambitious Boler restoration - '79 Model - Page 8 - Fiberglass RV
Old 06-23-2023, 11:37 AM   #141
Luis's Avatar
Trailer: Boler 1300 79'
Electric services run vertically on double bulkhead.
here a picture of removable panel and double bulkheads.
The panel has now installed 110V lights switches, 12V fused switches, receptacles for both 120V shore power or 110V from the 300W inverter.
12 V switches for:
Inside closet led lighting
Inside cabin lights
porch light
HVAC system (Computer fans forced ventilation through electrical, closet, fridge coils, propane heater...)
Other 12 v loads are locally switches, faucet, Roof fan, DVD, other.
Luis is offline   Reply With Quote
Old 06-23-2023, 11:41 AM   #142
Luis's Avatar
converter/battery charger panel
batteries go in the rear compartment, driver side, electrics are routed from panel to the front compartment where charger panel is.
Old 06-23-2023, 11:47 AM   #143
Luis's Avatar
cabin can be set ad double 52" wide bed, single, 4 people table
In this picture, the back single bed is set (missing thermarest mats), and the table is set in dinning/ games mode.
Also can be used as a home office in town.
Note front bed board stored under rear window.
When in full double bed set up, white table can be stored in same place, or used to block the rear window completely.
Old 06-23-2023, 11:53 AM   #144
Luis's Avatar
Water system includes Insulated water tank in read passenger side bench
Tank is fully insulated.
water lines too.
System includes, filling tap, tank, pump, hose input (one way valve down stream from pump discharge), and electric with spigot (turns on pump when opened)
Pump is installed forward of tank in passenger size bench's front compartment.
Tank fill froward of this, on the inside of trainer by the side of door, all discharge lines route around back of trailer all the way to sink.
Sink discharge line opens to the outside, where a gray water tank can be used as requires.
Old 06-23-2023, 12:01 PM   #145
Luis's Avatar
side view from outside
Water tank fill tap visible in "companion way" below the access bar.
nOte front vinyl cover behind relocated spare tire. a
All fibreglass openings where relocated to the front:
electric cooler ventilation
Propane heater exhaust
Municipal water connect
110 v 30A connect
Hose and cable storage
Old 06-23-2023, 12:06 PM   #146
Luis's Avatar
table can be relopated on the back window sill
And that way the front single bed (table seat) can be set up.
The table is supported by the Window sill and the back board on its long side.
Note that window sill width allows for white table to be placed vertically effectively blocking back window for blackout/ sleep mode, and is also works as a white board, or projector screen.
Old 06-23-2023, 12:11 PM   #147
Luis's Avatar
finally full sleep set up
We have 3 single Thermarest mats for seat backs or seat pads, and a double 52" red one for sleep.
In winter we add a feather pad under the sheets.
Note 3 side floating shelf in the top and DVD player in driver side.
Picture has back window unblocked and partially covered with wool blanket/ adjustable window drape, but white table could have been there
There is a separate wool blanked cover for the trailer door that helps with black out and heat loss.
Old 06-23-2023, 12:19 PM   #148
Luis's Avatar
Outside picture
You can see two jacks in the back bumper, that together with the front tongue jack, provide a three leg stable platform.
Roof mounted aluminum bars, were design for future solar panel install, canoe rack, etc.
in this picture they are anchoring a tarp prototype for a front water cover for the trailer. (self standing).
Note back window drape AND white table installed. Side windows blacked out with cardboard cut outs.
Hope you all like the updates.
Comments?
boler
Boler Restoration hudson Modifications, Alterations and Updates 13 07-03-2012 04:43 PM
Total Boler Restoration Jenny Jones Modifications, Alterations and Updates 16 09-02-2011 07:44 PM
Boler Restoration Kevin Dunno Modifications, Alterations and Updates 2 06-21-2009 04:42 PM
1976 Boler Restoration petramarc Modifications, Alterations and Updates 7 06-04-2006 10:33 PM
Boler Restoration Expert Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 09-30-2002 10:28 AM
