Scamp sink drain hose - Fiberglass RV
Old 01-16-2017, 07:34 AM   #1
BatDude's Avatar
Trailer: Escape
Hi all,
Our sink has been on the "slow" side when draining lately.
I did "boil out" the trap with baking soda and vinegar, but the drain hose from sink to gray H2O tank may need to be cleaned. I thought it would be easier to simply replace the hose and a lot neater job as well.
We use a lot of organic coconut oil in cooking and do use loads of dish detergent and pour very hot water down the drain regularly.
It appears to be 1" OD clear flexible tubing and ~ 3' long. Only two standard hose clamps on each end and both readily accessible.
An Amazon search for tubing has not turned up anything with that diameter all smaller or larger. Camco lists one as an RV drain, however this is ribbed and not smooth and appears to be 1.25" dia.
Ideas?
Guess I can call Scamp Tuesday and see what they suggest or if they can send me a replacement.
Cheers,
Bat Dude
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 01-16-2017, 07:37 AM   #2
Maybe look for hose used in a hot tub. I was at my local True Value, and there's reinforced hose that's white (not clear), but has a smooth inside. It's rated for hot water, which may help you since you're pouring hot water down the drain to keep it clear. I don't know the dimensions available though..
Good luck!
Old 01-16-2017, 08:55 AM   #3
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
I had the same problem slow drain. I found mine had a kink in it from the factory.
Ken in Pa is offline   Reply With Quote
Old 01-16-2017, 09:27 AM   #4
emij's Avatar
Trailer: 2005 Scamp 16
I actually bought new drain hose in that size from Lowe's Home improvement. They had it on rolls in various sizes, labeled food grade, bpa free, and I just cut off the length I wanted. Maybe you could find it there?
emij is offline   Reply With Quote
Old 01-16-2017, 09:54 AM   #5
Paul O.'s Avatar
I think Emily is right. Compare with what you find in hardware store. When searching on line by size, it is probable that the size references are about the I.D., not the O.D.
Old 01-16-2017, 10:27 AM   #6
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
This is the best answer. ^^^^
I've replaced a number of hoses with what Lowe's has. When you get the hose removed, measure the barbed fitting it slips on to.
Standard dishwasher hose might fit. It is 7/8" ID and some brands are pliable enough to slip over a slightly larger fitting.
Old 01-16-2017, 10:41 AM   #7
Trailer: Escape 21
Georgia
Paul O. really gave you a good direction to go with about the I.D. (inside diameter) vs the O.D. (outside diameter). The only time the OD will come into play is when going through the cabinet wall between the sink cabinet and where the inlet is for the holding tank. But there one can make the hole smaller if it is to tight. While the ID is the controlling factor for the hose. If you need a 3/4 ID to fit over the sink drain and the inlet to the holding tank then anything else will not work, or work reliably. To small and nothing you do will make it go over the connector, to large and you face the real probability of the connection leaking, not something you want happening.
When I replaced my grey water tank I had to heat the hose ends to get them over the fittings. In hindsight a pex tubing expander would have made the task much easier.
lijMichael is offline   Reply With Quote
Old 01-16-2017, 01:36 PM   #8
floyd's Avatar
check the vent line from the gray tank. if you have stuff stored under the bench it could have crimped it.
Old 01-16-2017, 02:42 PM   #9
Trailer: 2016 -13' Scamp
Massachusetts
Would this work?
https://www.grainger.com/search?sear...+hose+1%22+O.D.
herons is offline   Reply With Quote
Old 01-16-2017, 03:31 PM   #10
Trailer: Casita 17 ft. Liberty Deluxe
If possible, check the flow with hose disconnected from holding tank. Good way to eliminate vent problem.
J Ron is offline   Reply With Quote
Mold in Sink Drain Hose herons Care and Feeding of Molded Fiberglass Trailers 15 10-23-2016 06:16 PM
ParkLiner shower drain - kinked hose frank_a Problem Solving | Owners Helping Owners 20 06-24-2014 09:11 AM
Hose Buddy --For sewer hose Kevin K General Chat 5 12-09-2012 07:37 PM
Drain hose (sink) specs and availability? Darrell O Plumbing | Systems and Fixtures 3 09-07-2012 07:10 PM
Replace sink drain hose 13' Trillium HikeSticks Problem Solving | Owners Helping Owners 5 07-20-2010 08:48 AM
