Hello All,
My wife and I have recently purchased a 2008
Scamp 16'. We are interested in working on a few improvements over the next few months. One thing we are interested in accomplishing is new flooring. It currently has laminate flooring (i believe from the factory) that is in good condition, but really love the look of a vinyl wood flooring. I have read all different opinions but are curious what some of you think about this topic. Here are some of the questions I have!
1. Should I remove the laminate before installing the new flooring? If so, should I expect to see glue underneath the laminate from the factory?
2. Should the Allure Vinyl Flooring be installed "floating" or should I add glue for good measure?
3. Do you have to remove the benches to install flooring? If you do remove the benches, then do you drill through the new flooring for reinstallation?
4. If no glue is used for this flooring, then how do you get the one strip required for the step up to the dinette to stay?
Thank you so much for your help!
Craig
