11-30-2014, 08:45 AM
Georgia
front window on scampI
I have the gasket and window in but there is a gap on one side. How can I move it to center it.Could it be that is it only in the 50's out side. Thanks for all your help on here. Lee
11-30-2014, 08:51 AM
Trailer: (Dark side)Crossroads Now
Glade Valley, North Carolina
Is it thee original window. Do you have the right gaskets. More info and pictures would help.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
11-30-2014, 09:15 AM
Trailer: U-Haul 1985
Hi, Lee, I agree that some photos will go a long way towards giving people enough information to advise you.
FYI, your personal information under your name says you are 'Currently Shopping'. You can change your ID information to list your new trailer info now. Just go under User CP and you can upload the information and a photo avatar if you wish.
Congrats on the new purchase!
11-30-2014, 11:28 AM
Georgia
Yes it is a new window and gaskets from Scamp. I can't find how to up load pictures. Guess I can use help with this too. I see the icon that reads insert image but it is different then what I am used to doing. Thanks Jo
11-30-2014, 03:23 PM
Georgia
I just added 3 pictures but I only got them to an album Just can't see how to put them in the part. Thanks Joanne
11-30-2014, 03:32 PM
i deleted my comment as it does not apply to your situation, realized that after viewing picture.
11-30-2014, 04:23 PM
It looks like you have not installed the locking strip. The lock strip is what tightens up the gasket. It really helps if you have a Leslie lock strip installing tool and some Dawn dish washing liquid.
Eddie
11-30-2014, 04:30 PM
Georgia
tight fit
It seems that the gasket is hard and there fore I can't work the window in. Ordered the tool and it will be here tomorrow and will try again with it and dish soap. Is this a common problem that when you get to the end it is hard to push in. Thanks Lee
11-30-2014, 04:41 PM
If you can't get the plexi into the gasket you can put cotton clothes line into the window slot. Then press your plexi against the gasket and pull out your clothesline. The clothesline lifts up your seal and you can push the plexi into the groove. A cotter pin removal tool also helps pull the gasket out over the plexi.
Eddie
11-30-2014, 04:46 PM
Georgia
thanks
Thanks again will try that too. MY wife is in a hurry for me to get the windows done so she can start to clean and decorate. At this rate it will be spring before we are done. Lee
11-30-2014, 04:50 PM
The cotter pin tool helps pull the gasket over the plexi of you cant get the rope trick to work. You might want to dull the tip point a bit.
Eddie
Sears.com
11-30-2014, 04:53 PM
Georgia
The window is in all but that right bottom corner and I think what I need to do is move it and may have to take the whole window out and start over . Thanks again Lee
11-30-2014, 04:57 PM
Eddie
Would that be the Lisle 47000 lock strip tool? Spell check get you Eddie? Good suggestion to dull the cotter pin tool or it may poke through the rubber. There are other hook type tools available for radiator hose removal, NAPA has a good one for this type work, I used it on my Uhaul window after grinding down the point.
11-30-2014, 05:11 PM
Here are the photos of Lee's window
11-30-2014, 08:03 PM
I replaced all the gaskets on my windows. I used dawn soapy water and a rubber mallot. I held one side of the rubber head and pressed the gaskets in place with the other side of the rubber head. By the last few windows it got easier and I didn't even need to soap the gaskets.
11-30-2014, 08:30 PM
Georgia
window
Thanks I will try that in the morning. I may take the other corner out and then try again. Lee
