height of scamp - Fiberglass RV
Old 11-06-2016, 02:31 PM   #1
Trailer: obtaining information
Delaware
height of scamp
Does Scamp have a lift system to raise a camper a few inches higher like Casita campers do?
janisg is offline   Reply With Quote
Old 11-06-2016, 02:42 PM   #2
floyd's Avatar
Your question is really not specific enough for a proper answer.
Are you referring to a new Scamp?
What size Scamp?
If you mean a new Scamp, they commonly offer a lift for the 19ft Scamp 5er, to fit it to larger trucks.
If you are ordering a new Scamp16 you could request that they raise it on the chassis like they do the 19.
On the Scamp13 you could request a zero axle instead of an up 22.
When I said request, I meant just that, without predicting their response.
All Scamps now come with the axle bolted in place instead of welded, making a lift a simple matter for common skills.
floyd is online now   Reply With Quote
Old 11-06-2016, 03:29 PM   #3
Delaware
I'm sorry--I was thinking of buying a 13' Scamp. From pictures they look low to the ground. Casita has a high lift axle that is an option to lift the camper a bit higher. I was wondering if Scamp also has that.
Old 11-06-2016, 04:12 PM   #4
member
Isle of Wight
Or just buy one.....
Scamp (Dexter Torflex #9) Axle Lift Kit
WizWid is offline   Reply With Quote
Old 11-06-2016, 06:36 PM   #5
floyd's Avatar
Originally Posted by widgetwizard View Post
Nice... and even easier with the kit!
Old 11-18-2016, 11:58 AM   #6
Wisconsin
Had a lift kit put on our 16 ft. 2009 Scamp at the factory, to hopefully let us use larger tires. We previously had a blowout on the interstate and have become even more concerned about the safety of the 13" tires.
$700 later (cost of labor and axle), after trying 4 sets of tires, both 14" and 15" we are back to the original 13" size. There did not appear to be adequate room designed between the tire and fiberglass body to allow for larger tires.
The new axle does raise the body of the Scamp. Sorry, we didn't measure how much it raises it.
Ed and Pat in WI is offline   Reply With Quote
Old 11-18-2016, 01:35 PM   #7
Delaware
Thank you all for all your input. It's nice to know that there are a lot of knowledgeable people to help when there is a question or problem. Thanks again.
Old 11-18-2016, 02:53 PM   #8
BillE's Avatar
Trailer: Scamp 16 ft
There is the issue with Scamp axles being Lippert
Scamp now uses a Lippert axle so the bolt pattern for the Dexter lift may not work. (don't know for certain)
And to boot, there is a welded center "support" for lack of a better term, going from the center of the axle up to the frame. I will take a picture latter on tonight to show what I mean.
Our shop made me a 3inch lift kit t but have not installed it yet due to the welded support. I know I could grind it off and have a new one welded on but just haven't done it yet.
We will stay with the 13in wheels and tires but I would like a bit more body ground clearance.
A three egg family..
(2) Big Green Eggs for cooking..(1) Egg for camping
BillE is offline   Reply With Quote
Old 11-18-2016, 04:24 PM   #9
member
Isle of Wight
The Dexter lift kit wont work on the Lippert axle - but Lippert make a lift kit too....
JIm
Old 11-18-2016, 04:59 PM   #10
Byron Kinnaman's Avatar
The one question I would ask you, why do thing you would need it raised higher?
Old 11-18-2016, 05:03 PM   #11
member
Isle of Wight
I am not the original poster - but I know that many folks need to raise the body to avoid scraping the rear end when going over dips etc.
Old 11-18-2016, 07:22 PM   #12
I hear what you're saying but, the OP doesn't even own a trailer yet.
I've scraped a few times with mine, rarely but not impossible. The part that scrapes is the bolt and nut that holds the ball on to the ball mount.
There are ways to avoid scraping, one is to approach things at an angle rather than straight on.
So again I'm wondering what OP has in mind when worrying scraping?
Old 11-18-2016, 09:58 PM   #13
BillE's Avatar
Here are the pictures of a center brace on a Lippert
These are the pictures of our 2016 Scamp 13ft Deluxe with a Lippert Axle.
As I posted... I will grind this off and make a 3inch longer bracket ..have the boys weld it back on.
Old 05-26-2018, 05:48 AM   #14
Work still in progress...
This is being done on my 2015 13' Scamp with the Dexter Axle #9 using kit #K71-723-01...
I still need to bolt on an angle steel bar and then attach the axle to it...
Steve1234 is offline   Reply With Quote
Old 05-30-2018, 04:08 PM   #15
Finished but still needs to be taken out for a ride/test...
Scamp 5th wheel truck bed and rail height Rhys H Towing, Hitching, Axles and Running Gear 4 07-18-2008 10:55 AM
Inside height on Scamp & Casita matt scott Care and Feeding of Molded Fiberglass Trailers 12 03-04-2006 10:05 AM
interior height on scamp campers Legacy Posts Problem Solving | Owners Helping Owners 11 08-21-2003 09:26 AM
Inside height on Scamp & Casita General Chat 0 01-01-1970 12:00 AM
Scamp 5th wheel truck bed and rail height Rhys H Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
