Confirmation of R-value of Scamp? - Fiberglass RV
Old 05-19-2018, 10:01 AM   #1
Trailer: currently shopping
Montana
Does anyone in this community have any information that could confirm that claimed R-value of 15 for the Scamp? Such confirmation could be measured R-value or at least photos showing the inside of the walls (perhaps from a window or vent replacement) that would confirm the presence of an air cavity.
Why am I asking? I’ve been looking for a fiberglass RV to be used in Alaska shoulder seasons when the outdoor temperatures could easily be 0 and below, and was settling on a Scamp because of the claimed R-value of 15, which is double that of the other fiberglass RVs (Escape and Casita) and of “regular” RVs.
As a former house builder and recently retired research scientist, I was curious how Scamp achieved this R-value and because I am looking for a used RV, I wanted to find out when Scamp started making RVs with this R-value. I called Scamp and spoke with their excellent customer service people, who told me that Scamp began making R-15 walls in 1987, not to provide better warmth but to prevent condensation on the interior walls when used in cold temperatures. And that this R-value was achieved using 2 layers of foil-faced “bubble wrap” insulation. I asked if Scamp had an independent lab test this claimed R-value, and the customer service person said (paraphrasing): “No, and we won't bother doing that because we've lived in these in Minnesota when it's 0 degrees outside and they are very comfortable with the heater on.” This statement is similar to the formal response on Casita’s FAQ page in response to the question, “What is the R-rating of the insulation in a Casita trailer”: “As our customers put it – ‘Cool in summer’ and ‘Warm in winter.’ So far, no complaints.” I also asked the Scamp person if they had any photos showing the inside of the wall, and the answer was “No.” In my opinion, these responses from Scamp and Casita are inadequate and disappointing. I called both Casita and Escape to find the actual R-value and was told R-7 for both based on a layer of foam board inside the fiberglass shell.
The issue with foil-faced bubble wrap insulation in the Scamp is that it requires a dead air space to achieve the claimed R-value. There are many online articles from building engineers about how foil-faced bubble wrap, when it's sandwiched within other layers without an dead air space, have an R-value of 1-3 (from the air bubbles), not nearly the claimed 10-20 because these higher R-values only come from the dead air space that needs to be designed next to the foil facing. Here's a quote from a company that only sells foil-faced bubble wrap insulation: “In order for a radiant barrier to be effective, it requires a dead airspace on at least 1 side of the product. If you sandwich a radiant barrier between two solid materials, then heat will just conduct through it, rendering it ineffective.”
I fully realize that in a relatively small volume space such as a 13’ or 16’ Scamp (or any other fiberglass or other RV), as long as it’s weather tight, a small heater will adequately and comfortably heat the space. But a R-value of 15 compared to 7 will have a significant impact on both comfort and the quantity of propane or electricity used to maintain this comfort. I’m asking the fiberglass RV community for input on this not to give Scamp a hard time, because Scamp clearly makes an excellent RV, but to make a major buying decision based on facts and not unsubstantiated manufacturer claims.
I apologize for this long post, and would appreciate any insight the community can offer.
PeterBL is offline   Reply With Quote
Old 05-19-2018, 10:17 AM   #2
Jon in AZ's Avatar
I can confirm that the R-value of Scamp's insulation is nowhere near R-15. Last I checked they were deleting that information from their product descriptions. Your information about the ratings and use of foil-bubble wrap is correct.
Even if it were, the large expanse of single pane windows and exposed plumbing (on bathroom models) makes the Scamp a mild weather trailer. Good down to around freezing and short spells below (with precautions), but not for winter use in cold climates.
What Scamp does is a hack. It works reasonably well in practice because, as you observe, it doesn't take much to heat or cool such a small space. The nap on the marine headliner is probably helping a little as it traps dead air. It is very effective at preventing condensation.
BTW, somewhere I did see a photo of the lining sandwich. There is only one layer of foil bubble wrap, consisting of two sheets of bubbles between the layers of foil. No significant air space.
Old 05-19-2018, 11:28 AM   #3
Montana
Hi Jon, thanks for the input and confirmation that I'm not crazy! On the Scamp website, under the Showroom section, it still says "Super insulation (R15)" under the description of standard features for 13' and 16' campers.
Old 05-19-2018, 12:15 PM   #4
Jon summed it up well but I might add even if the insulation was R45 it would not make much difference. With all the non-air tight and/or single pane windows, non- insulated vents, uninsulated floor and ill fitting door, its not much better than a tent sometimes.
Old 05-19-2018, 01:04 PM   #5
Trailer: scamp
R value
This issue regarding R values is no more than a sales technique. It is important to understand heat moves in 3 ways, conduction, convection and radiation. The material they are claiming is "Super Insulation", if properly installed is an effective radiant barrier, unfortunately a radiant barrier is not much use when it's 0 degrees at midnight, and that is assuming a perfect seal from air leaks. The biggest problem I see is that is legal to make these claims.
I have a 2016 Scamp 13 which I am insulating for winter use. As has been illustrated elsewhere those single pane windows R value probably hovers around 1, not too good. I have found a company, Motion Industries, in Vancouver WA that makes double pane windows for RV's. For cold weather these are basically mandatory. Of course there are other manufactures of this product, but being a west coast guy I favor our regional companies.
Sealing air leaks makes a very large difference, particularly around the bottom of the door which works about as well as a sieve. Has anyone found an effective way of stopping this problem?
BTW, anytime you see a tiny trailer with a 16000 BTU furnace you know there is some kind of design issue, unless you are trying to heat the outdoors!
Nick
Nick J is offline   Reply With Quote
Old 05-19-2018, 01:17 PM   #6
honda03842's Avatar
Name: Norm and Ginny
Trailer: Scamp 16
Scamp in the cold
We're in Newfoundland again this ?Spring?. It's cold. Actually the world temperature according to NASA has dropped 0.6 C over the last two years, some kind of recent record. It has been particularly cold up here this year with relatively high winds.
It's certainly true that our 27 year old Scamp leaks air almost making our CO detector a joke. However it is also true that the Scamp is easy to keep comfortable.
We're at a Music Festival. When we return home after the evening concert the trailer after the two hours concert drops from 70 F to 40 F. When we return Within an easy hour it's back to 70. We do also have an electric blanket that quickly warms the bed. In the morning simply cooking breakfast has us warm and toasty.
We do disconnect our hose at night since temperatures can freeze the hose. We woke to a surprising 24 F and the other morning a frozen hose. I took the hose to the campground shower and cleared it in a few minutes.
Our more clever son, with us in his trailer in NL, has a heated hose gifted to him by a park member in FL.
If I were trying to improve the weather ability of my Scamp, there are many areas where spray foam could make an improvement, particularly around our fridge. Of course thermopane windows would be a great Scamp option. I love the thermopane windows on our second son's Tab 400.
We have modified our Scamp significantly and there are a lot of ways to slow the flow of air. Maybe next year.
All in all our Scamp is now 27. It takes us all over. People continually stop us for tours and to tell us they love the shape.
We have been traveling for 18 years, the last 10 in small trailers, we know they're faults, all rigs seem to have them, yet it gets us where ever we want to go in relative comfort. It's like marriage, it may not be perfect but it can be pretty good, and that's enough.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 05-19-2018, 01:18 PM   #7
John in Santa Cruz's Avatar
Mid Left Coast
our Escape 21 has the extra insulation package, double pane windows, and underneath foam spray..... I can confirm its WAY warmer inside in cold weather, and the heater runs a fraction of the time as it did in our Casita 16, even tho the inside of the trailer is probably twice the volume. its also way quieter inside.
the only really winterized FG trailers are the olivers and bigfoots as these have an inner and outer FG shell with serious insulation between them.
Old 05-19-2018, 01:18 PM   #8
floyd's Avatar
I was writing that almost verbatim when my screen glitched!
You are right on the mark (except for that last phrase)
Fact is, The wall covering the best choice in its class, but it is not a four season trailer...nor was it designed as such.
Peter;
It is perfectly clear that you were not looking for confirmation!
Old 05-19-2018, 05:28 PM   #9
tractors1's Avatar
Trailer: Escape 21 - Felicity
I winter camped at Yosemite in a tent while on a snow shoe tour using mummy style sleeping bags with only a Coleman lantern for warmth. Any trailer is better than a tent!
Charlie Y
Old 05-19-2018, 05:58 PM   #10
Originally Posted by Nick J View Post
BTW, anytime you see a tiny trailer with a 16000 BTU furnace you know there is some kind of design issue, unless you are trying to heat the outdoors!lo
Nick
Not many RV propane furnaces less than 16K BTU (I only now of one). Many people get by fine in a Scamp when its near freezing outside and when on shore power with a ceramic heater on low, which I think works to well under 3,000 BTUs. I dont think that Evelands chose the furnace so much based on BTU rating.
Old 05-19-2018, 08:25 PM   #11
floyd's Avatar
Scamp went to the 16000 from the 12000, mine is the 12000, still overkill.
I just figured they had quit making the 12000.??
The heat strip in the A/C is really great when you have shore power.
Old 05-19-2018, 09:10 PM   #12
Trailer: Scamp 13
If you ever sealed up a Scamp 13 as air tight as you would like what would you breathe.
Old 05-19-2018, 09:15 PM   #13
Mike Magee's Avatar
Trailer: 2012 Escape 19
Oklahoma
The Bigfoot's ceiling insulation is R-8. Not significantly different from the Escape with its 'extra insulation' option.
By comparison, an Outdoors RV has R-29 in its ceiling. (But it's big and heavy, of course.)
Old 05-20-2018, 01:28 AM   #14
Trailer: scamp
stevebaz
LOL,
Sealing a volume as tight as you are suggesting is damn near impossible. But in practical terms i tend to keep a window cracked for fresh air, BUT I am modifying my Scamp for winter use in NW WA, in the past I spent several days in a class B in minus 25 F weather, remarkably the difference in temperature between the top of the table and the floor was appx 40 degrees F. That was not much fun, also sucked up a lot of propane.
Having more than 2 decades in the Environmental technology field, that is HVACR to most people, I know the value of insulating and being able to do the calcs for heating and cooling loads for myself, has led me to the conclusion most trailers are pretty darn cheep. I use a Dickenson P 9000 heater, combustion is totally contained (combustion air comes from outside) plus it flickers like a real fire - neat! The BTU rating is 3500 to 4500 appx, and has proven to work very well in 20 degree F weather. Looking forward to that first 0 minus night.
Old 05-20-2018, 09:34 AM   #15
BatDude's Avatar
Trailer: Escape
Air leaking in by fridge
AS Norm noted,
Scamps do leak air ... LOTS of it through the exterior fridge vents. The compartment is not really sealed and the platform that the fridge sits on had 3/4" gaps in the corners and ~ 1/4" along the exterior side. This allowed outside "ventilation" to dump cold air into the storage area under the fridge.
I replaced our platform with a tighter fit and sealed the edges with foam weather stripping. This warmed up the lower area of the Scamp appreciably just by stopping the cold air flow down the inside wall into the lower storage compartment then leaking through to the floor.
Our new Escape will have much better insulation. Having said that with an electric cube heater we have been comfortable even in the high teens low 20s °F. Yes, when the propane jet engine (AKA furnace) ignites it will convert a chilly Scamp into a Sauna in 10 minutes or so.
Bad Dude $.02 worth
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 05-20-2018, 10:02 AM   #16
Trailer: I'm now married to a 16 Foot 93 Scamp!
R-Value of a Scamp
HURRAH ! This is such a valuable thread for me! Since I am slowly renovating my 93 16' Scamp, I have learned a lot about what I can improve for the cold weather in western North Carolina.
Thank you to everyone that contributed to this thread!
I love this website!
Sara from Coral Springs, Florida
Cybercuban is offline   Reply With Quote
Old 05-20-2018, 10:06 AM   #17
tractors1's Avatar
Originally Posted by BatDude View Post
AS Norm noted,
Bad Dude $.02 worth
The compartment with combustion gases with a propane appliance (aka fridge, water heater) is supposed to be sealed from the inhabited spaces and is specifically addressed in the appliance manuals; both my Casita and Escape were very well sealed - to prevent any CO from entering the trailer.
Charlie Y
Old 05-20-2018, 04:30 PM   #18
Mike Magee's Avatar
Oklahoma
My Li'l Hauley is very tight, with hardly any air leakage (just a bit around the door and maybe the window slides which fit loosely in their tracks). An all-electric Snoozy would probably be similar.
I have thought about the feasibility of adding 3 or 4 inches of insulation to the ceiling of the Hauley up the point where it begins to curve downward in front. Heat tends to rise, so that is where insulation would do the most good. It wouldn't be too hard, I think. And there would still be plenty of head space.
Old 05-20-2018, 06:12 PM   #19
floyd's Avatar
AS Norm noted,
Bad Dude $.02 worth
My Scamp13D has the fridge completely sealed neatly in place and has displayed none of the problems you describe. The only real problem has been in truly cold conditions the windows cascade cold air. That problem is mitigated significantly by using custom cut reflectix window covers.
Also, the bathroom door needs to be left open in really cold conditions since there is no heat source inside.
That being said...
We really prefer the under the floor mounted climate control system supplied with every new Scamp and powered by the TV.
With rare exceptions and in concert with the optional appliances onboard, it is this CCS, when properly used, which keeps us consistently comfortable.
Old 05-20-2018, 07:17 PM   #20
Trailer: Trails West
While it would be difficult to keep the cold out you can do things to be more comfortable. Do reflective heat barriers help? Yes and that dead air space can be the actual interior volume itself. If I were trying to stay warm in extreme climates then a reflective barrier would be my interior wall finish in the cold season.
The way I will do it is to create some removable sections of reflective material that snap or velcro into place. Using some thickened epoxy I can adhere small disc of wood to the shell and then screw snap stud bases or tack some velcro into those disk. Then when I need the reflective blanks I will snap them on. When I don't need them I can roll them up and stow them away. A few small silver stud bases here and there on the interior are not that objectionable looking. You could do this reasonably easy and not all that expensive of an adaptation to most any of the trailers with rat fur or Ensolite interiors. Of course you will have silver walls for part of the year but it will also reflect the light around the space making it feel brighter on those days of short sunlight.
I am epoxying disc onto my ceiling before I put the head liner up. I have large flat areas over the bed section of my Campster, and in the pop-top roof section too so it will be very easy to make some reflective blankets to install overhead during the colder months. I have 3/8" thick EVA foam insulation adhered to the ceiling so I will use 3/8" thick plywood disc that won't be visible once the headliner is applied over the foam. You will just see the snap fittings. I could put little vinyl caps over those if I wanted to but I won't.
Agreed Upon Value for Scamp CampyTime Money Matters 6 10-08-2014 08:15 PM
13 ft Scamp value Don Gr Classified Archives 12 03-20-2011 10:35 AM
Blue Book Value vs. Resale value Markz Money Matters 5 01-04-2011 07:56 AM
determining value of 83 scamp 5th wheel? Coach George Jessup Problem Solving | Owners Helping Owners 5 04-22-2009 10:05 AM
Scamp Used Value Steve R General Chat 10 09-04-2007 02:32 PM
