Broken Scamp sink trap - Fiberglass RV
Old 06-11-2018, 03:19 PM   #1
Trailer: Scamp 16'
Indiana
My 16' scamp sink drain broke at the barbed outlet to the waste water vinyl tubing. I purchased a new trap and also ordered a stainless bar sink drain as the original was pretty corroded. My problem is that the new trap is very loose on the new stainless drain threads. It really will not catch the threads until it is nearly all the way on the drain, and this means that there is not enough room for the nut that holds the drain in place. I'm thinking of installing the drain with silicone sealer on top side of the sink and installing the rubber compression washer under the sink and then using more silicone on the drain threads to seal the trap as I screw it up against the compression washer.
Here's my question. Is my solution for snugging the trap up against the compression washer without the compression nut a good one or should I look for better fitting trap and drain?
Thanks for any help, Tom
FlyboyTJ is offline   Reply With Quote
Old 06-11-2018, 04:56 PM   #2
Trailer: Trails West
Take the pieces with you to a local hardware store and show the clerk the issue. They will sort you out with something that works. Don't do this at Home Depot, Lowes, etc go to an ACE, True Value or Do-it-Best. Or find a plumbing supply store where they sell both fixtures and fittings. A good old fashioned style hardware store wins hands down for help with odd plumbing jobs. Don't go first thing on a Monday morning or right at closing time. Saturdays tend to be way too busy as well. Go during slack time when they are less pressured.
Old 06-11-2018, 05:33 PM   #3
Trailer: Scamp 16'
Indiana
Thanks K for the suggestion. An old hardware store that has survived all the big box stores comes to mind. I'll check them out tomorrow.
Smiles, Tom
changing sink trap-1994 Scamp jessesouza Problem Solving | Owners Helping Owners 12 10-09-2023 05:08 AM
Broken Sink Pipe Wallo Problem Solving | Owners Helping Owners 2 07-21-2013 09:20 AM
Shower trap same as the sink trap in a Scamp? Bryan L. Plumbing | Systems and Fixtures 6 01-14-2010 02:56 PM
How to remove drum trap on sink? Kevin Dyck Problem Solving | Owners Helping Owners 3 06-25-2009 10:03 PM
