Burro Axle Downangle - Fiberglass RV
Old 03-26-2015, 03:05 PM   #1
Trailer: Burro
Hello... I'm committed to replacing the axle on my '79 Burro and trying to decide on downangle. Some questions:
- I'm interested in possibly going to slightly larger tires (15"). It looks like there is no wheel well problem here. Any advice here?
- It seems like I would benefit from the increased ride height offered by the 22 degree down option because of higher hitch height and the preference to having a slightly forward leaning trailer rather than back. On the other hand, maybe the increased height may add to instability. I should note that my tow vehicle has pretty good ground clearance. Any thoughts here?
- I'm worried that maybe the 22 degree down angle might 'look weird' on the trailer with wheels too far out of their wells, violating the original spirit of the trailer. Thoughts?
- The step up. Is this a problem? I have no issues with using a step on the ground but will this get old real quick, leaving me longing for the 10 degree?
- What is the actual difference in inches between the two?
- Does 22 vs 10 have a difference in the quality of the ride for the trailer and its non living occupants?
- What is the original spec?
- I took measurements. Anyone want to share theirs so I can feel more or less confident in mine?
- Am I overthinking this? Sorry for the super long text above, but I wanted to do some crowdsourcing on this.
'79 Burro, Rochester NY
samuelm is offline   Reply With Quote
Old 03-26-2015, 03:19 PM   #2
Ian G.'s Avatar
I have consolidated all the ground clearance measurements on a Dexter #9 axle for a Boler based on 175st tires with a diameter of 24" This may give you a good idea for your Burro
Proud Canadian- Boler Axle
Old 03-26-2015, 05:55 PM   #3
Trailer: Burro
I forgot to note: I plan to convert this to a trailing arm (it's leading now). This is easier as the Burro has a single level floor. I also was planning to leave the old axle in place, cutting the arms off flush with the frame sides as not to lose origins structural benefits of the axle in that location. Because it's near the wheels it shouldn't affect ground clearance.
Old 03-26-2015, 07:37 PM   #4
member
Isle of Wight
I will take the easy question.
the difference betwen a 10 deg down and a 22.5 deg down on a #9 is about 1.3 inches
Jim
http://l.b5z.net/i/u/6149609/f/Trail...nformation.pdf
WizWid is offline   Reply With Quote
axle, burro
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
