Trillium battery ground question - Page 2 - Fiberglass RV
Old 08-18-2017, 08:57 PM   #21
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Generally put a battery cutoff switch on the positive conductor between the battery and the fuse panel.
In my Trillium rig I actually have a double pole single throw switch on the positive conductor that allows me to switch back and forth between battery and (shore) power supply. I don't have a converter.
Old 08-19-2017, 05:35 AM   #22
Trailer: Trillium 1974
Saskatchewan
Hi, I looked at several youtube videos and some seem to agree that using it on the negative wire is safer (since you always unplug black wire first.. was one of the reason). Once again, I have no knowledge in this area and still learning. All I can say is that Internet is full of contradictions :-) thanks
wysiwyg is offline   Reply With Quote
Old 08-19-2017, 05:36 AM   #23
Saskatchewan
Sorry by black I meant white (ground). Anyway, I might go on the positive side then.
Old 08-19-2017, 06:16 AM   #24
wysiwyg, I don't know a specific reason for attaching the cutoff switch to positive battery conductor vs negative.
My DPST switch is on the positive conductor and it has 3 positions (battery, (shore) power supply, and off). If you install a converter or 12vdc power supply (as I have done) at some point, you will probably want to do what I have done, i.e., LP detector ON using battery power or shore power if either are available.
Old 08-19-2017, 06:54 AM   #25
wysiwyg, I forgot to mention an important point: The DPST switch on the positive conductor was wired that way 40 years ago by the Trillium manufacturer. But I don't know why using the negative conductor wouldn't work as well.
Old 08-19-2017, 07:05 AM   #26
Saskatchewan
Thanks again for the advice. For now, I dont have a converter but I'll install it on the positive side between fusebox and battery.
battery, trillium
Question on Bigfoot ground clearance spartacus Towing, Hitching, Axles and Running Gear 27 08-29-2013 05:39 AM
battery, ground and a few other questions Mike Whitney Problem Solving | Owners Helping Owners 7 05-30-2011 03:37 PM
ground question Randy Dewey Problem Solving | Owners Helping Owners 6 07-30-2007 11:46 AM
Prodigy.. electrical battery ground ? Christi V. Problem Solving | Owners Helping Owners 16 04-20-2006 10:19 PM
