replacing wood around window - Fiberglass RV
Old 09-03-2017, 04:32 PM   #1
trillyowner's Avatar
Trailer: Trillium
Maine
we just bought a 1975 trillium, it has a leak around the front window and i think we have to replace the wooden frame. any suggestions on prep, things to watch out for, etc?
trillyowner is offline   Reply With Quote
Old 09-03-2017, 09:04 PM   #2
Roy in TO's Avatar
There are a few good threads on how to do this. Dave Tilston's come to mind. Mikmay too.
http://www.fiberglassrv.com/forums/f...ead-65342.html
Old 09-04-2017, 08:14 AM   #3
Trailer: Trillium
Maine
Thanks a lot
Old 09-04-2017, 05:24 PM   #4
Trailer: 1976 Trillium 1300
New Brunswick
I would suggest you only take one window out at a time you may need to get measurements from another the same size. I would remove a screw on each window and check it's threads. It there aren't any left you will need to do all the windows because the wood is so bad it wouldn't hold a new screw at all. My '76 Trillium was in that condition. You will need access to a table saw to make the new wood pieces. Most everything else just needs hand tools. The edge of the wood is beveled at 45 degrees on the outside edge all around. Use a putty knife to peel back the ensolite covering to gain access. I used spray contact cement to re-install it on mine. Good luck! Go slow so you don't damage anything.
getaway1 is offline   Reply With Quote
Old 09-04-2017, 06:02 PM   #5
Trailer: Boler13/trillium4500/buro13
My suggestion is to not replace the frame with wood but to use pvc or composit flat stock which is readily available at lowes or Home Depot. It will cut on a regular table saw and will never rot again. Just use a salvaged piece to match.also make sure to replace the screws with stainless or aluminum
Mikmay is offline   Reply With Quote
Old 09-04-2017, 07:08 PM   #6
Trailer: Trillium
manitoba
I agree with Mikmay. PVC and stainless screws. I also used spay on contact cement to glue the ensolite. I would also recommend getting a glazing bar tool. Can not live without one of those. I would recommend getting good quality butyl tape from your local RV dealer.
Reade is offline   Reply With Quote
Old 09-09-2017, 10:14 PM   #7
Trailer: Trail Cruiser
I suggest you not replace with wood if possible. A polymer (PVC etc) is a permanent repair and I find it easier to work with.
Mike_L is offline   Reply With Quote
Old 09-11-2017, 05:59 AM   #8
JRTrillium's Avatar
Name: Janice & Rick
Trailer: Trillium 1300
Nova Scotia
Is there a way to 'flag' certain threads so they can be referenced later, quicker? I like this info and short of printing it off . . . . which I can't . . . . would like to be able to reference my most needful topics.
JRTrillium is offline   Reply With Quote
Old 09-11-2017, 06:20 AM   #9
Jon in AZ's Avatar
Originally Posted by JRTrillium View Post
Is there a way to 'flag' certain threads so they can be referenced later, quicker?...
I subscribe to the thread (but turn off notifications). To subscribe, use the "Thread Tools" menu at the top of the first post on the page. Set notification preferences in the "User CP" at the left of the task bar under your log-in information. To return to your subscribed threads later, there is a link in the "Quick Links" menu on the right side of the task bar.
I believe another member copies and pastes the URL into a spreadsheet with subject fields in order to reference many useful threads quickly.
Old 09-11-2017, 08:09 AM   #10
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Thanks! Wouldn't it be nice if there was a 'like', 'acknowledged' button? Too FBook'y probably - I like people to know I've read their response.
Have a lovely day, all.
trillium
Trillium window wood, dry out or replace buk Care and Feeding of Molded Fiberglass Trailers 29 01-13-2023 11:18 AM
Replacing fiberglass interior parts with wood? (Scamp) GrregP Modifications, Alterations and Updates 36 09-12-2017 03:43 PM
Screw holes. How do I repair the old screw holes around the Window. BeckyK Care and Feeding of Molded Fiberglass Trailers 5 07-17-2017 07:03 PM
Replacing the Gasket around the door of my Perris Pacer 1985 plant_sandwich Problem Solving | Owners Helping Owners 8 10-17-2016 04:23 PM
Trillium Wood Window Frames Legacy Posts Problem Solving | Owners Helping Owners 4 11-06-2002 11:24 AM
