Advice on Scamp 13 power please - Fiberglass RV
Old 06-27-2015, 09:58 AM   #1
Power Control Center. I don't see a model number.
The Inteli Power PD9130 has a 3 prong AC power plug that is not plugged in.
Should I plug this into the AC power jack on the Power Control Center?
ID label on Inteli Power PD9130
Wires from Inteli Power PD9130 to Power Control Center. Also AC jack. Plug PD9130 into this?
cootcraig is offline   Reply With Quote
Old 06-27-2015, 03:26 PM   #2
rbryan's Avatar
Arkansas
The converter must receive shore power. If the block in your third photo is where the shore power comes in, then you'd plug it in there. The PD9130 is not designed to be hard wired on the AC side. This a really simple connection, but if you don't know what you're doing, I'd highly recommend you let a pro do it.
Old 06-27-2015, 03:46 PM   #3
Bob Miller's Avatar
Trailer: Class A Motorhome
That looks like a Progressive Dynamics power control center with a total of 6 AC breakers. One should have been dedicated to the converter. Take a look at what each one is connected to and you should find one is connected to that AC outlet you mentioned and is intended for the converter. If not, it's easy to have one added to the existing breakers and use that for power to the PD3190. I'd almost bet that some of those breakers are currently unused.
Old 06-27-2015, 07:06 PM   #4
It is a Progressive Dynamics power control center, but I don't see any model id.
The AC outlet on the back of the power control center is on an AC branch
circuit breaker.
I've tracked these AC branch circuits.
1) Main
2) AC outlet for converter
3) Sink cabinet power outlet and fluorescent light
4) ??
5) Air Conditioner unit
6) ??
I would think 4 or 6 is the refrigerator circuit. Is there an easy way to
tell when the refrigerator has AC power?
Old 06-27-2015, 08:36 PM   #5
Trailer: Scamp has Arrived - Layout 7
Minnesota
By all means do plug it in. We have the same set up and that darn plug has a habit of coming out of the receptacle every now and then. Some day I may get around to figuring out a clip or clamp of something to keep it from vibrating out.
Dan
Dan Jones is offline   Reply With Quote
Old 06-27-2015, 10:37 PM   #6
Bob Miller's Avatar
The 120VAC for the refrigerator is usually a plug, plugged into an outlet behind the refrigerator. You can check that outlet for power or just turn it on, set the refrigerator to 120VAC operation and, in about 30 minutes, see if the outside of the boiler cover starts to get warm.
If one has a plug falling out, it might just need a new receptacle as this usually doesn't happen and a loose connection will run hot in use, making it even looser.
Old 06-28-2015, 11:57 AM   #7
Not necessarily Bob. My scamp has the identical setup. Unfortunately, they don't finesse their design on anything they do. My power cord is rammed in there with NO compartmentalism in mind at all. My cord has made mine to come unplugged from my panel as well. On the other hand, Progressive should have had a little more positive restraint designed in themselves.
I've read where some have used zip ties to hold them in. I haven't figured out what I'm going to do yet. It IS difficult to get to.
Old 06-28-2015, 11:47 PM   #8
Roger C H's Avatar
Cool Receptacles
I installed a new receptacle for my front hall (in my house, not my Trillium). I think I accidentally bought a hold tight design because it is difficult to plug and unplug things in it.
Surf Side: Purchase Advice please! Rachie D. Problem Solving | Owners Helping Owners 5 04-13-2012 04:14 PM
Advice please, what would you do? sfoss Problem Solving | Owners Helping Owners 7 02-20-2012 08:49 AM
Fellow eggers, a little advice on Generators please. rgbekker Hi, I am.... 38 02-11-2012 12:38 PM
1976 "Scamp" decal size advice please Mike L. Problem Solving | Owners Helping Owners 3 06-25-2011 12:17 PM
Advice on Scamp jalousie window screens please Mike L. Problem Solving | Owners Helping Owners 2 06-25-2011 12:05 PM
