Doran Bus LED's on my 1996 13' Scamp - Fiberglass RV
Old 07-03-2015, 10:31 AM   #1
Trailer: 13' Scamp
Wisconsin
Need help replacing the tail lights on my Scamp. I followed forum advise to purchase 7" Doran LED bus lights to replace the existing lights after calling Scamp and learning they do not make that type of tight anymore. Anyway so the new lights have a red, black and white wire (is this a ground?) while the old lights had a red and green wire in one bulb, a black wire to the other bulb and a white ground. Do I ignore the green wire? Just do red to red, black to black and put in a small screw for the white wire? This is probably stupid, but I really don't have a clue. Thanks for any help.
EllyArt is offline   Reply With Quote
Old 07-03-2015, 11:45 AM   #2
For what it's worth and until someone else answers up, this is information I gathered a while back about the conversion to bus lights:
Just for reference, since a lot of us seem to be installing these LED lights (highly recommended). Just cut off the old lights and solder to the wires on the outside is the easiest thing to do with no messing around inside. So:
black is reverse
green is tail light
red is turn light
white is ground
I believe the LED lights are:
white is ground
black is tail light
red is turn light
Hope this helps.
Old 07-03-2015, 05:11 PM   #3
Trailer: 13' Scamp
Wisconsin
Wish I understood it better but I will give it a try per your directions, Donna. I will post how it goes.
Question on Wiring 12V Fuse Block with Negative Bus kellyben Electrical | Charging, Systems, Solar and Generators 8 01-24-2018 05:40 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
Bus Depot awning Tom Trostel Modifications, Alterations and Updates 8 07-11-2010 07:24 PM
baby on the bus Roy Bakehorn Jokes, Stories & Tall Tales 2 04-10-2008 10:08 AM
» Trailer Showcase
Award
cynnbad
Bolar
11acs
