Option for Original Burro Kitchen Light - Fiberglass RV
Old 10-29-2018, 10:33 AM   #1
Trailer: Burro
Nevada
We have a 1982 Burro and I removed the original 120v wall-mounted kitchen light since it took up so much space and had a fluorescent bulb. We are trying to decide what to do with the bare wire. It runs to a plug box that runs off shore power. I'm not able to find any lamps that run off 120v that are small enough for the kitchen wall. Should we remove this wire? Attach an outlet to use for small night light or fan? There doesn't seem to be a ground wire, so we are wondering what is the safest thing to do. Any ideas?
viajera80 is offline   Reply With Quote
Old 10-29-2018, 10:43 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
You could re-wire to your 12vdc fuse panel and install a 12vdc light fixture.
Old 10-29-2018, 11:06 AM   #3
Trailer: Burro
Nevada
Hmmm...I don't think our Burro has a 12v fuse panel. The wires for the 12v lights run directly from the battery.
Old 10-29-2018, 11:47 AM   #4
If those wires are from a 120V source it is most likely from the outlet that is in one of your pictures. that outlet has the little push button breaker that is similar to what was in our Uhaul. If you don't find a replacement light you may want to trace the wires back and disconnect them. Are you sure it was a 120 light as our Uhaul had two 12 volt lights that used a fluorescent bulb.
Old 10-29-2018, 11:56 AM   #5
Doesn't need to be back to a 12vdc fuse panel. I'll reword: back to a 12vdc power source.
Old 10-29-2018, 11:58 AM   #6
Trailer: Burro
Nevada
Thank you. Yes, the wires come from the outlet with a little push button breaker. It was a 120 since the light would not work unless we were plugged in.
burro, light
Burro bunk option erasmsn1 Problem Solving | Owners Helping Owners 15 08-16-2020 09:23 AM
Kitchen or no kitchen? AJCmedia Modifications, Alterations and Updates 44 04-02-2016 03:25 PM
TAKEN ~ Free - original interior light. Liz&Kev Classified Archives 1 05-05-2011 11:48 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
LED lights in Original light sockets Gerry Modifications, Alterations and Updates 21 01-05-2007 02:03 PM
