Trillium electrical ? - Fiberglass RV
Old 10-23-2014, 01:15 PM   #1
Nortondawg's Avatar
Hi. 78 Triilium. Converter doesn't convert, however the ac outlets work when camper is plugged in...until last night. Fuse WAS NOT connected yet power was fine untill last night....hmmm? Anyone? Thanks!
Nortondawg is offline   Reply With Quote
Old 10-23-2014, 02:42 PM   #2
David Tilston's Avatar
The fuse is for DC. The AC is taken care of by the push button breaker. If the white button is sticking out, push it back in. It should be noted that this breaker is rated at 10A. Many large loads, like a 1500W heater will trip it.
Old 10-23-2014, 03:00 PM   #3
Nortondawg's Avatar
Thanks David! White button is inside converter?
Old 10-23-2014, 03:29 PM   #4
Nortondawg's Avatar
No white button :-(
Old 10-23-2014, 03:34 PM   #5
Nortondawg's Avatar
Got it! Thanks!
Old 10-23-2014, 03:52 PM   #6
I have a spare converter. If you want DC for your lights, I would be willing to part with the fuse holder. PM me if interested.
Old 01-31-2015, 10:10 AM   #7
Martins HeirCon's Avatar
Trailer: Trillium 1300
Georgia
My '75 1300 came to me with no converter, no panel, nothing. Can you guys show me what it would have looked like originally?
At present I have only a junction box in the floor of the closet. The power cord comes to there, and then branches to a receptacle under the fridge and one over the counter( through the floor of the upper cabinet).
Martins HeirCon is offline   Reply With Quote
Old 01-31-2015, 10:20 AM   #8
Bob Miller's Avatar
Trailer: Class A Motorhome
I don't know what it had of if it had anything originally, but you might want to look into installing a Progressive Dynamics PD-4045 Power chassis/converter to replace what you have, give you expansion room for ac circuits, fused DC circuits and a 3 stage "Smart" battery charger. They are currently standard equipment in many new FGRV's and I have installed a number of them with excellent results. Available from on-line sources for well under $200
Old 01-31-2015, 02:24 PM   #9
Georgia
Thanks, Bob.
That's actually the charger I have installed already. I mounted it under the front bench beside the fridge. I just have it plugged into the same receptacle as the fridge. That way, in the unlikely event that I ever plug in to shorepower the battery is automatically charging. So far it's only been plugged in at home occasionally.
I just thought it strange that there's no circuit protection at all on the AC side. I've been wanting to add a small switch/breaker panel just inside the door. At present I have the switches for my 3 LED zones on the window frame to the left of the upper kitchen cabinet, just because it was convenient to wire it there while I use the camper and ponder on it a while.
Old 01-31-2015, 02:37 PM   #10
Bob Miller's Avatar
Hmmm. The PD-4045 has provision for 4 AC circuit breakers and is designed to be your AC power center.
Old 01-31-2015, 03:01 PM   #11
Georgia
Let me go look at that thing and confirm model number. It was given to me, and I haven't laid eyes on it in months. I just remember the brand, don't have the literature for it. Seems like I recall it just has a couple of DC fuses.
Old 01-31-2015, 03:11 PM   #12
Georgia
I misspoke. It's a PD9260C.
Name:   ImageUploadedByFiberglass RV1422738708.372287.jpg
Old 01-31-2015, 03:36 PM   #13
Bob Miller's Avatar
That's a good one, but it's a converter/charger. I will look up the number for the matching ac/dc distribution panel they make for your consideration.
Old 01-31-2015, 03:45 PM   #14
Bob Miller's Avatar
That's the converter/charger part and a very good one at that. Here's a link to the matching PD-5000AC/DC distribution panel that will give you all the AC & DC distribution you need
http://rvpowerpartsplus.net/index.ph...roducts_id=340
Fixed Link.....
Old 01-31-2015, 04:17 PM   #15
Georgia
Thanks much! Looks like that's the smallest one they offer? Guess I'll just have to get used to the idea of cutting a hole in the 'glass...
Old 01-31-2015, 04:47 PM   #16
Bob Miller's Avatar
They have a smaller one that's DC fuses only. the PD-6000 series:
PD6000 Series DC Power Distribution Panels
I had installed two of these when AC breakers weren't needed.
Old 01-31-2015, 11:10 PM   #17
FTTRV's Avatar
Trailer: tp
Bob have you seen a Shurton Inverter? A friend has a 1978 with this unit. He needs a breaker.
Chuck
FTTRV is offline   Reply With Quote
Old 02-01-2015, 11:47 AM   #18
Bob Miller's Avatar
Yep, in fact I have a Shurtron 715-006 in front of me right now that I use as a DC power supply for bench testing. As I recall, I took it out of a 1978 Sunrader
It has a 120vac/15 amp Push-to-reset breaker and a an unmarked circuit breaker for 12VDC. As the tag sez 15 amps DC max, I'd bet that the DC breaker is also 15 amps.
They appear to be standard components in this package size: Boat Marine Panel Mount Circuit Breaker Push to Reset Switch 20 Amp | eBay
Should be an easy part to find locally.
I'll bet that this anwer surprised you..... LOL
electrical, trillium
Electrical problems with a 1979 Jubilee Trillium Leonard31 Electrical | Charging, Systems, Solar and Generators 9 05-24-2014 03:29 PM
Help! Electrical Gremlin Aboard cyndi H Problem Solving | Owners Helping Owners 2 07-22-2009 06:48 PM
Battery/Electrical - Trillium 1300 '74 Mark Fitz Problem Solving | Owners Helping Owners 12 07-16-2009 06:53 PM
electrical - 4 way vs 7 way - questions DaleT Problem Solving | Owners Helping Owners 3 05-14-2009 07:08 PM
Trillium Electrical Problem Legacy Posts Problem Solving | Owners Helping Owners 4 07-19-2003 12:44 AM
