Wheel bearing 13 ft scamp 2003. 2005 - Fiberglass RV
Old 05-29-2017, 09:45 AM   #1
Trailer: Scamp 13
Where to purchase a set. Also proper procedure for packing and tightening nut. And is it protical to only pack the outer bearing. Thanks stump
Stump is offline   Reply With Quote
Old 05-29-2017, 05:16 PM   #2
Trailer: 13 ft Scamp
I believe the last set i purchased was at napa
Take the old ones w/you
Ive always done both
Since i had the wheel pulled
Old 05-29-2017, 05:22 PM   #3
Trailer: Scamp 13
Thank you I only did the outer. When I take wheel off. Will the inner bearing b easily removed? do I need to take the race need a special tool or is it as easily removed as the outer. This was first time I did one thanks again
Old 05-29-2017, 05:36 PM   #4
Many people have written up great HOWTOs and / or produced video instructional guides on trailer bearing maintenance. There is nothing special about the ones on Scamps. They have Lippert or Dexter axles and bearing assemblies. I would use Google.com to find them and review them since they will (as a rule) be much more detailed and informative than the brief replies you will get here.
Also the owners manual for your axle (Dexter or Lippert) should have the process explained.
I would however caution you that some of these online guides are contradictory or just plain wrong in some aspects, so after you review a number of them, ask here to clarify anything you need to.
Buy from NAPA, e-trailer.com.. or 100 other places. Quality varies some but its hard to tell what you are buying anyway.
If you do it.. do both inner and outer. If you need to replace a bearing.. replace the races also (and thats a bit more complicated but also explained online on 100's of online sites).
Old 05-29-2017, 05:52 PM   #5
I agree w/gordon
Completely
Old 05-29-2017, 05:55 PM   #6
Trailer: Scamp 13
Much thanks to all. Ron
Old 05-29-2017, 06:52 PM   #7
No, Thank you.
I was afraid you might think I was blowing you off.. and thats not the case. In fact I am getting ready to do my own bearing repack. I have only done it a few times, so I am taking my own advice and reviewing the procedure.
Its not that hard but one reason I am reviewing it is the differing opinions on the finer points. Just one example... what is the best solvent to use to clean the old grease off the bearings? And do you really to to clean them at all or can you just force new grease in to force out the old grease? My take is that since I am using a different brand of grease , I should use a solvent (kerosene maybe, followed with brake cleaning spray) to clean them first. That also allows you to better inspect them for damage or wear.
But the worst I ever saw in an online guide was a guy who reused the cotter pin.
Never reuse the cotter pin!
Thats why you want to see the advice from different people and use your common sense.
Old 05-29-2017, 07:03 PM   #8
Trailer: Scamp 13
I did not think that at all. Thanks again ron
Old 05-29-2017, 09:13 PM   #9
floyd's Avatar
Since you have EZ lube there are no cotter pins to concern yourself with.
Yours are 1-1/16" spindles available everywhere from Walmart to any boat or parts store. Use any good quality lithium grease.
https://www.youtube.com/results?sear...d+trailer+axle
Old 05-30-2017, 01:17 AM   #10
Trailer: Scamp 13
Great info Floyd thanks. I was sfrsid to pull grease seal knowing niwbthey rcreafily available I will take wheel off and check and pack inner. I already did outer I guess it is a complete re do. If I tell nspa suto or ? That is1 1/16 spindle they should give proper seal and bearing if needed . Is that correct. Thank you agsin
Old 05-30-2017, 01:23 AM   #11
Trailer: Scamp 13
Floyd I deleted. Somehow ur contact no. Please send again. In case of thanks ron
Old 05-30-2017, 05:47 AM   #12
likeair2me's Avatar
Trailer: SCAMP
Missouri
From the Scamp page
Stump, for your reference take a look at the Scamp page.
https://www.scamptrailers.com/parts-...ning-gear.html
My '81 Scamp 13 uses the L44643 Timken Cone. Timken is about as standard as you can get.
likeair2me is offline   Reply With Quote
SOLD - 2003 Casita Spirit Deluxe and 2005 Honda Odyssey Nancy Wright Classified Archives 10 03-15-2009 02:57 PM
Problem With Wheel Bearing Randy Bishop Towing, Hitching, Axles and Running Gear 3 06-16-2008 07:21 PM
Wheel Bearing Check Anders Laurits General Chat 7 12-16-2007 09:05 PM
Wheel bearing survey John Perry General Chat 15 12-15-2007 06:50 PM
Problem With Wheel Bearing Randy Bishop General Chat 0 01-01-1970 12:00 AM
