Vintage scamp repair questions - Fiberglass RV
Old 06-07-2017, 08:23 PM   #1
I may be buying a old scamp it doesn't have the cushions for the beds are these reproduced and where is the best place to find them? Just wondering on the cost. Also how difficult is it to replace the lining on the windows if the leak?
Any other common problems with scamps from the 70s I should be aware of?
Pezking82 is offline   Reply With Quote
Old 06-07-2017, 09:02 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Scamp, the manufacturer, will sell you the cushions, cushion covers, and cushion foam. Here is the link:
https://www.scamptrailers.com/parts-...et-fabric.html
Old 06-07-2017, 09:04 PM   #3
likeair2me's Avatar
Trailer: SCAMP
Missouri
Unsure of the question...
What do you mean about window lining and replacement?
And what vintage are you talking of, because there have been changes through the years.
likeair2me is offline   Reply With Quote
Old 06-07-2017, 09:14 PM   #4
It's a 77 The seller said he thought the rubber seal around the windows could be replaced
Old 06-07-2017, 09:17 PM   #5
window leaks
Regarding window leaks:
If any of the tilt out windows leak, remove the window, clean and re-seal the mounting flange to the fiberglass using 3/4" x 1/8" butyl tape, then re-fasten.
If non-opening plexiglass front or back windows leak, remove window, clean edge of window and fiberglass, and re-install using new rubber molding.
Other possible concerns:
- torsion axles lose shock absorbing capability after 15-20 years (replace axle)
- plywood floors collecting water from leaks tend to rot over time (repair or replace rotten floors, but also find the leaks)
- propane lines should be inspected, leak tested
Old 06-08-2017, 11:38 AM   #6
Thanks that is helpful
scamp, vin
Vintage curtain tracks -- need vintage snaps Mara Modifications, Alterations and Updates 5 05-29-2013 05:50 PM
'86 Bigfoot 17" repair questions andix Problem Solving | Owners Helping Owners 7 04-04-2013 04:03 AM
Fiberglass/plywood floor repair questions ... freddo411 Modifications, Alterations and Updates 6 12-11-2011 09:45 AM
Fiberglass repair Questions Kenny H Problem Solving | Owners Helping Owners 9 09-04-2008 10:20 AM
Newbie questions on towing/repair Sharyl Allender General Chat 23 05-28-2006 11:03 PM
