Originally Posted by jplumber
...you can see the frame go into the body. has anyone seen this before? When I look under the camper the frame looks fine but the body seems to be sagging. is this from a rotten floor or ?
I am dealing with a similar problem in my Compact Jr's rebuild, but only in one rear corner under where the kitchen sink was. I suspect that un-noticed leaking plumbing may have contributed as the wood floor had a water stain. But that alone could not have cracked the
fiberglass? I speculate that hitting a pot hole in the road jarred that area enough to crack the
fiberglass, and not finding and addressing the initial crack allowed it to open up and settle around the frame.
