SAGGING Roof on "early" 13ft BURRO - Fiberglass RV
Old 04-16-2017, 04:30 PM   #1
Trailer: BURRO
The ROOF on my "early" 13 ft BURRO is SAGGING in the area just at the rear of the Roof Vent in the "center middle" --- I can push it UP by hand to it's normal position ---
Any of you have this problem and can suggest a "FIX" or can suggest a "fix" even if you don't have the problem with your BURRO ???
Any suggestions would be greatly appreciated ---
JOHN
John D Reinhard is offline   Reply With Quote
Old 04-17-2017, 06:42 AM   #2
Trailer: UHaul CT13
Iowa
John,
'Surprised no one's weighed in on this. I know a number of us with U-Haul campers have had issues with sag in the roof---from a heavy roof-top AC unit, or a tree branch laying across it, or even heavy snow-load in winter.
Perhaps a search for "sagging roof"?? Or you could join the U-Haul [Burros welcome FaceBook page for more discussion?] As I recall, the first suggestion is usually to prop up the roof from inside, probably raising it a little more than usual, and letting warm sunny days "relax" the sagging f/g.
At least one member "over there" has propped the sag up, and then fiberglassed a stiffening rod to the underside of the roof---in the middle, where the ceiling carpet strip would hide it. Another is I think in the process of [1] temporarily removing the roof vent fan, and then [2] sliding pre-shaped wooden ribs from side to side in between the inner and outer skins---presumably using thickened f/g resin or some-such to bond the ribs to the skins.
'my $.02's worth..........
Gary
Old 04-17-2017, 09:23 AM   #3
Thumbs up Roof
I have redone 3 burros with the same issues. Ok hears what I did went to home depot bought some 1inch wide aluminum about 6 foot long bent to shape (easy to do) Use a mall stainless bolt and nut the nut on the inside I the center. Then drill for the rivets and there you have it, When you cover the inside no one will no but you. Have fun a grate little camper and a piece of history.
Philmay1 is offline   Reply With Quote
Old 04-17-2017, 10:52 AM   #4
Scoboatn's Avatar
Trailer: Burro
I used Bondo Glass to repair some seams on my camper. Super stiff and sticks really well. You could prop the roof to shape and spread a 1/4" layer or so on the roof seam. I like Phimay1's idea. Maybe use the bondo-glass to hold the aluminum supports in place?
Scoboatn is offline   Reply With Quote
burro
sagging roof in 17' boler Dawn S Problem Solving | Owners Helping Owners 13 07-17-2009 12:20 PM
Fixing a sagging roof from the inside... kentj Problem Solving | Owners Helping Owners 7 02-17-2008 08:35 PM
Sagging roof..... kentj Problem Solving | Owners Helping Owners 2 08-29-2007 09:52 PM
Roof Sagging On Our Bigfoot TT ???? mitch Problem Solving | Owners Helping Owners 32 05-12-2007 09:46 PM
sagging fiberglass roof on Surfside ericmarlo Problem Solving | Owners Helping Owners 3 08-31-2006 01:35 PM
