We have a '96 SD 17. Had a little problem one time with the switch on the panel that is on the front of the
fridge. When I turned it to run on shore power (110) the switch turned hard and I didn't get in the correct position. All OK after repositioning it. I think you know, and checked, that the
fridge is plugged in the outlet that you see when removing the outside lower panel.
