Escape hatch plastic cover removal? - Fiberglass RV
Old 10-03-2016, 05:58 PM   #1
jefflarsen's Avatar
Trailer: Interested
2002 13' Deluxe. After deflating tires to 15# I could get the Scamp in the garage if I could remove the plastic bubble on the escape hatch (darn things peaks like the pyramids). In kind of a hurry. Needs to go to storage if I can't remove that lid. Looks like the fantastic lid removes pretty easily. Thanks.
jefflarsen is offline   Reply With Quote
Old 10-03-2016, 06:15 PM   #2
I just replaced an escape hatch cover. You have to take the drift pin out the regulator. Then the lid just slides off. If you are going to make a habit of removing the escape hatch you might replace the drift pin with a bolt and nylock nut.
Eddie
Old 10-03-2016, 06:19 PM   #3
jefflarsen's Avatar
Trailer: Interested
Eddie
What is the "drift pin"?
Old 10-03-2016, 06:49 PM   #4
The gear box that you crank the vent open is the regulator. The long arm that goes up to the hatch cover uses a drift pin as a pivot point. The pin is pressed in, It's best to press it out. It can be driven out but the housing is cast and you could break it if you are not careful driving it out.
With standard vents the two screws that hold the regulator in place can be taken out and you can separate the arm from the lid but that did not work with my escape hatch.
Eddie
Old 10-03-2016, 07:06 PM   #5
jefflarsen's Avatar
Trailer: Interested
Thanks Eddie. I see the pin. Darkness is descending on never-never land so I'll go at it in the a.m. I'll try the screw approach too..but since I see the pin that's probably the ticket. When you say "press" it out instead of "drive" it out. What's the difference. Sorry, I was a Liberal Arts major. J
escape
"Porch light" plastic cover Ev in Oregon Problem Solving | Owners Helping Owners 22 12-29-2019 11:10 PM
Plastic propane cover . Wallo Problem Solving | Owners Helping Owners 0 04-08-2014 06:57 PM
Where to find plastic cover for water/electric? Panoz77 Problem Solving | Owners Helping Owners 10 01-18-2012 05:11 PM
71 Boler 13' Floor Removal/ Shell removal mikeandmadi Problem Solving | Owners Helping Owners 1 05-23-2011 10:28 AM
Does your awning arm cover a hatch? jrnutpaul Problem Solving | Owners Helping Owners 3 11-02-2006 07:46 PM
