Biggar door latch - Fiberglass RV
Old 07-14-2017, 02:37 AM   #1
Trailer: Biggar
Manitoba
Biggar door latch
I have a Biggar camper and the lock is wearing our inside the door latch and doesn't really lock anymore. Anybody know where I could get another one for this camper or something with similar dimensions to fit. It's a bigger square door latch
biggar1 is offline   Reply With Quote
Old 07-14-2017, 02:55 AM   #2
Trailer: Biggar
Manitoba
....also has anyone ever mounted a a/c unit on the roof of one of these behind the roof vent hole (cut a new hole for the a/c unit itself and still have the vent). Where did you wire it too and did you need to change out the converter in the trailer to power it?
Old 07-14-2017, 08:33 AM   #3
Dudley's Avatar
Trailer: 1998 Casita 17 SD
a picture would be good of the latch, I have a bargman l300 some where in the garage which is what it sounds like. You can also replace with a more modern one such as a trimark as some have done. Pictured is a l300
Old 07-14-2017, 08:48 AM   #4
Trailer: Biggar
Manitoba
ID:	108681Click image for larger version
Old 07-14-2017, 08:50 AM   #5
Trailer: Biggar
Manitoba
Defitnetly the l300. Would you happen to have a pic of the trimark,curious to know what it looks like
Old 07-14-2017, 12:36 PM   #6
Don't know about your latch, but I have heard that NEW YORK IS BIG, BUT BIGGAR IS BIGGAR - Biggar Sask, that is,
Old 07-16-2017, 03:09 PM   #7
Dudley's Avatar
Sorry was away for the weekend. If I can find the one I have your welcome to it. Trimark replacement kit
Old 07-16-2017, 04:42 PM   #8
Trailer: Biggar
Manitoba
Ok how much would you like for it.
Old 07-16-2017, 09:24 PM   #9
Dudley's Avatar
I will try and find the Bargman L300 tomorrow and you can have if for the cost of shipping. Its used but I cleaned it up and made a key for it(homemade key). I know its in the garage but built a new garage last year and I am still trying to find stuff
PM me with your address
Old 07-16-2017, 09:33 PM   #10
Trailer: Biggar
Manitoba
Ok thank you very much that is much appreciated. Virden Manitoba, Box 2876, R0M 2C0, full name is Damien Mowez.
Old 07-17-2017, 05:57 PM   #11
Trailer: biggar
biggar door latch
I don't know if this will help with your a/c question, but my biggar's a/c opening is 33 inches from the centre of my front vent to the centre of rear/c vent , right where the fridge sit's, there might be an vent hole already up there and they just panelled over as a/c wasn't called for , the power wires from what i could see run towards the fridge an down to the power centre, Removed my air conditioner and capped off the wiring , put in a maxx fan.
mike mcbiggar in b is offline   Reply With Quote
Old 07-17-2017, 05:59 PM   #12
Trailer: Biggar
Manitoba
I know there is another opening up there because in the am when the morning dew is on the roof you can see the square on the roof
Old 07-17-2017, 06:01 PM   #13
Trailer: Biggar
Manitoba
So there is factory wiring running to that spare hole behind the paneling already? I know I have a spare 20 amp breaker in the camper I wonder if that's what that us for? Wasn't sure if the panel would handle a newer a/c unit although it does run the window a/c unit.
Old 07-17-2017, 06:02 PM   #14
Trailer: Biggar
Manitoba
I also put a maxx air fan in my vent hole and want to keep it because I have no vent for my stove was gone when I bought the camper
Old 07-17-2017, 06:34 PM   #15
Trailer: biggar
Biggar door latch
I don't know if there is factory wiring up there , the old wire that is up in my bigger is stiff as a board , you could take out the fridge, I had to and then run wire over and down inside the wall between the fridge and stove,I dont know about your biggar but mine didn't have nearly enough venting to get rid of the heat ,it does now , my 40 year old fridge chills down to 25 degrees now that can breathe.
Old 07-17-2017, 09:10 PM   #16
Dudley's Avatar
found the l300 and is boxed up and will post it tomorrow. Found a spare key blank as well as the one I made.
Old 07-17-2017, 10:31 PM   #17
Trailer: Biggar
Manitoba
Ok thanks again man
biggar
1979 19' BIGGAR the "Biggar Boler" - Tearful Sale Casandra F Classified Archives 21 08-13-2009 09:50 PM
Door Latch - Lock Seized Kurt in BC Problem Solving | Owners Helping Owners 10 09-08-2008 07:16 PM
Wanted door latch for Burro Sally Stoner Classified Archives 4 07-26-2006 08:54 PM
Door handle and latch replacement for a '75 Boler KenReiss Problem Solving | Owners Helping Owners 9 07-15-2006 11:51 AM
Door Latch Legacy Posts Problem Solving | Owners Helping Owners 3 04-21-2003 09:49 PM
