Bigfoot 17 drop to straight axle - Fiberglass RV
Old 09-09-2013, 10:53 PM   #1
Trailer: Bigfoot 17' DLX
Alaska
In preparation for my trip home from Alaska to California this fall I finally replaced the drop axle with a straight version as we discussed in this older thread...
http://www.fiberglassrv.com/forums/f...7cb-41542.html
The only thing I didn't do as planned was use the optional 3" diameter 5,200 lb. axle tube. As it turned out I would have had to special order it and the time and expense to get it to Alaska didn't justify it for me. The regular 3,500 lb. axle, along with all new hubs, brakes, etc. was all in stock at a local Dexter distributor so I had them put it all in for me last week.
The drop to straight axle conversion did exactly what I wanted, gave me about 4-inches of lift. Plus, now everything is new (axle, hubs, brakes, springs) and the E-Z Lube hubs will make servicing easier.
As you can see in the photos before and after, the ground clearance is significantly higher now, which is what I was after. Now I don't have to worry about scraping the dump valves and associated plumbing in the bad spots on the Alcan. The "acid test" starts in a couple weeks.
trainjunkie is offline   Reply With Quote
Old 09-10-2013, 07:08 AM   #2
cpaharley2008's Avatar
Excellent modification, looks great.
Jim
Never in doubt, often wrong
Old 09-10-2013, 08:09 AM   #3
I finished up the same project a few weeks ago and I am very happy with the way things turned out. I used my existing brakes and hubs as they were in very good condition. Towing characteristics did not change. I've had 2 short "shake down" trips no problems. The big test starts later this week. I'm heading to Utah to see the national parks.
Much easier to empty the holding tanks too.
You did a nice job.
Old 09-10-2013, 10:18 AM   #4
Alaska
Jack,
Good to hear the towing characteristics didn't change. Right now my truck is empty and the trailer is at its lightest so the tongue is ever so slightly high. I'm counting on the load of stuff I will have in both the truck bed, and some food/clothes and full propane tanks in/on the trailer, to get the tongue just about level. I'm hoping it tows nicely once it's level. It's not bad now but it should be even better when level.
The Fastway® Flip™ jack foot I installed a few months ago now works as intended and makes using the jack MUCH faster and easier. It was useless at the original height but I installed it in anticipation of the extra height from the new axle and it works perfectly now.
I too had considered reusing the original hubs and brakes (original Standens stuff), and I mention this only for those researching this conversion, but I wasn't too confident that the previous owner had taken care of the chassis very well. Because all my shop equipment and most of my tools are in California, I had to have someone do the labor and as it turned out, the parts and labor to refurb the hub bearings (bearings, seals, grease) and replace the consumable parts on the brakes, actually cost more than just buying all new components, even including new leaf springs. So for those not doing the work themselves, you might want to look into the difference in cost between refurbishing your original components (if they need it) versus replacing them with new components which require significantly less labor to install.
If I had all my shop equipment here, or was doing this in California, I probably would have gone the same route Jack went though and saved a few bucks. This whole thing, parts and labor, cost me $759.00. To have my original hubs/brakes refurbed and transferred over to the new axle the quote was $900.00. Why? Labor in Alaska is a staggering $100/hour!
Old 09-10-2013, 01:40 PM   #5
Brian B-P's Avatar
I'm glad to hear that there was no noticeable degradation, but it does not seem physically possible that raising the trailer caused no changes to the dynamic behaviour of the trailer. It is probably an effective and safe configuration, but stability and resistance to rolling over will be reduced.
This is much like driving a truck or similar SUV and describing the handling as "just like a car"... it may be in normal conditions but when pushed the differences show up.
Old 09-10-2013, 02:04 PM   #6
Nice did you go for bigger tires looks like you have the room.
Daniel A. is offline   Reply With Quote
Old 09-10-2013, 06:43 PM   #7
Alaska
No. I bought the tires before the axle change. The tire/wheel package I installed is here: http://www.fiberglassrv.com/forums/f...7-a-57340.html
Frankly, I didn't want larger tires. I plan to drag this thing around in the dead of winter, which means chains/cables, and a lot of ice build up in the wheel wells. I prefer having some room in there even if just to make installing traction devices easier.
Old 09-01-2014, 05:32 PM   #8
Trailer: BIGFOOT
New lift
How was the new lift riding now?
CAMPER DOUG is offline   Reply With Quote
Old 09-01-2014, 05:47 PM   #9
Alaska
Honestly, I have no idea how it rides. Nobody rides back there when it's being towed. But even on the crazy, bumpy Alcan, I rarely find anything out of place in the trailer, and have never found anything broken. It tracks and tows beautifully and the increased ground clearance really makes it easy when you get off the main highway.
One thing I also added later were wet shackles, which really makes it ride a lot quieter. No more squeaking and groaning as I go down the road. And no squeaking inside the trailer when I walk around in it. Best mod ever!
http://www.fiberglassrv.com/forums/f...oot-62285.html
Old 09-01-2014, 07:38 PM   #10
I did the same conversion a little over a year ago and I'm very pleased with the resulting ground clearance. I have not noticed any changes in ride. Two trips to Utah and Arizona on lots of BLM roads convinced me it was a good upgrade. I have not added any provision to lube the shackles but may do that later. One thing I would probably do differently would be upgrade to a higher capacity axle. When I weigh my trailer with a moderate load I'm close to the maximum capacity of the axle. Going to a larger capacity axle adds considerably to the cost. A 5200# or 6000# axle requires new brakes, drums, hubs, wheels and tires.
axle, bigfoot
straight axel for 1973 hunter 1 keysday Towing, Hitching, Axles and Running Gear 8 11-28-2013 12:21 PM
How Do Court Reporters Keep Straight Faces? Cyndi B. General Chat 8 07-05-2013 08:54 AM
Drop Axle Turned Upside Down? KeesV Problem Solving | Owners Helping Owners 17 04-09-2013 02:31 PM
Drop down bed 17 foot bigfoot. biggoolies Modifications, Alterations and Updates 9 10-17-2012 11:07 PM
Need the straight info on pricing (NADA) Legacy Posts General Chat 14 07-27-2003 09:00 AM
