Perris Pacer Axle alignment - Fiberglass RV
Old 02-28-2015, 11:55 AM   #1
Fredomatic's Avatar
Trailer: 1974 Perris Valley Pacer
Need advice - Perris Pacer Axle alignment
Hi Everyone
I hope you are doing well.
I am planning to lift the egg off of the frame to check thoroughly for possible damage. Now I see that the wheels are not centered in the wheel well. Is this by design or a mistake during a previous axle repair? I'm probably the third or fourth owner so I'm not sure if and when the axle was moved. Shouldn't the wheel be centered in the well?
Fred
Name:	ImageUploadedByFiberglass RV1425145731.963644.jpg
Fredomatic is offline   Reply With Quote
Old 02-28-2015, 03:19 PM   #2
Trailer: Perris Pacer 13'
Hi Fredomatic,
We have an "81" Perris Pacer, your wheel placement appears to be the same as ours.
ratty3 is offline   Reply With Quote
Old 02-28-2015, 03:31 PM   #3
Does it look the same on both sides? If you are goint to do all that work now would be the time to install a new - Bolt on axel. Something to think about.
Old 03-01-2015, 10:07 PM   #4
Fredomatic's Avatar
Darwin
The axle looks straight as the wheels are in the same location on both sides. If I don't end up moving the axle, does the bolt on assembly allow me to lower the axle so the wheels don't ride as high in the wheel wells? Given the amount of times the trailer scrapes or bottoms out, i think it would help.
Ratty
Maybe it's me but from the photos, I think my axle is a tad further forward than yours. Do the swing arms on yours swing towards the front or back? Mine are towards the front.
Fred
Old 03-02-2015, 07:43 AM   #5
Fred, swing arms toward the front.
Old 03-02-2015, 09:01 AM   #6
Once you Raise the frame by inserting a spacer between the frame and the axle, that will give you more room for the wheel to flex up. Once you convert from a welded to a bolt on axle, that gives you or future owners the ability to change out new axle on your own in just a couple of hours. If you decide to do a new axle, think about brakes B 4 you order one. You can get an axle with all the stuff already on it. Good Luck.
Old 03-07-2015, 09:38 PM   #7
Fredomatic's Avatar
Thanks Darwin and Ratty. The bolt on axle is definitely a consideration. Now to research the best way to remove the egg from the frame without cracking it.
Old 01-06-2021, 02:35 PM   #8
Trailer: '88 Perris Pacer - 13 Footer
West
Hey Fred. Thanks for the help in my last thread regarding the 82 Pacer I'm in the processing of buying. Looks like it's going to be our soon, which is very exciting.
I'm fairly certain this thing is going to need a new axle. I figure it's worth it to pull the body off to inspect the frame and make the axle work simpler.
I'm wondering how you went about removing the body from the frame. Specifically:
1. You said there were four bolts in back, and four in front. Were all of these easily accessible? Just free the nut from the bottom of the bolt, I assume?
2. Are there any other bolts or other attachments points to remove before lifting?
3. How did you go about lifting the shell? Is it light enough that a couple of strong bodies to get enough lift to slip cross supports underneath it, then pull the frame straight out from underneath?
82_Pacer is offline   Reply With Quote
Old 01-10-2021, 02:04 PM   #9
Fredomatic's Avatar
Lots of details! Feel free to ring me. I left you a PM with my contact info.
Cheers
Fred
axle, perris pacer
Axle Alignment bobsimpson Towing, Hitching, Axles and Running Gear 2 07-11-2013 05:36 AM
13' Perris Pacer Frame and axle work... to do rudock1 Problem Solving | Owners Helping Owners 24 02-06-2013 08:57 PM
AXLE ALIGNMENT D Tharp Towing, Hitching, Axles and Running Gear 8 09-10-2009 10:43 PM
13 ft Perris Pacer ~ $2700 Gina D. Classified Archives 3 06-02-2009 12:22 PM
